Front Bumper Outside Ambient Temp Sensor (with photo)
Hi Boxster owners,
The front bumper outside ambient temp sensor on my Boxster went haywire, so I removed it and replaced it with a new one.
The sad part is, I forgot whether or not if the sensor sits flush against the clip or not. It was a struggle to get the original one out, but I was also no longer able to plug it back in fully. The new one is clipped in (as pictured) and held on by the clip/harness, but to reiterate, I can't remember for the life of me if it's supposed to sit flush or not. And if it is supposed to sit flush, how do I push it back in far enough? It's not working for both the old and new sensor. I hope I did not break anything!
For what it's worth, the new sensor does work and the cabin temperature is comfortable now. Before, the fan would go from full blast to nothing in a matter of seconds.
Could a fellow Boxster owner take a look for me to confirm? Thanks in advance!
I got the part from my local Porsche dealer. The Porsche part number is 95850553500, and is the updated version of the sensor. It is also compatible with various models throughout the Porsche line. Are you looking to replace yours?
Pelican sells it, except the factory simply refers to it as a temperature sensor - Click here for the direct link to the part itself. I tried to shop around however, could not justify buying more items as I had just purchased everything required for fall/winter maintenance. Good luck!
Pat M,
That definitely sounds like a bad sensor. Please do follow up to see if the replacement solves the issue for you. I think this part is often forgotten and almost never replaced until we see the temp off the charts. I'd be really curious to see how this works for you. It's been a few days since replacing the sensor for my Boxster, and the results have been positive. I'm not roasting in it anymore!
Pat M,
You'll probably need the schematics to the wiring diagram. I'm no help on that but if you search around, I'm sure you'll be able to find it.
Edit: Perhaps this might help? https://www.renntech.org/topic/8232-...r-temp-sensor/
