Tight Shifter?
3rd Gear
Tight Shifter?
I'm new to the Boxster world, but not to Porsches. I just bought a 6-speed 2002 S and haven't seen it yet. I did have a PPI done by a local independent high-end shop, and it checked out in all respects. Hubby went up today to complete the deal and bring it home, which was his first time to lay eyes on it. He reports that the shifter is "tight," especially when cold. Is this a common issue? And does it require a trip to my Porsche whisperer when I get it home? Understand that I haven't driven it yet due to illness, but apparently it's tighter than our 997. It's had a new clutch/IMS within the past 20,000 miles, along with other maintenance and upgrades.
Thoughts?
Thoughts?
If it doesn't grind or pop out of a gear it is very common. My S is hard to shift into 2nd the first time when cold, but as soon as it has driven 1/4 mile it is fine. I am going to try adjusting the shifter when I replace the shifter bushings soon. If that fails I'll replace the cables.
The 6 speed gearbox can be particular about what oil is used. For mine I refilled it with the Porsche product after experiencing some balkiness in second gear. I don't know what was in it but putting in the real stuff cured my cold shift issue.
This is the part number from the PET
999 917 546 00
transmission oil
HYPOID
1 LTR.
container
I purchased mine from the local Porsche dealer and the part number on the container is
996 917 546 00
75W90 Hypoid Gear Oil
Have fun with your car.
999 917 546 00
transmission oil
HYPOID
1 LTR.
container
996 917 546 00
My 2007 Carrera had a 6sp and it was tight into 1st & 2nd. I believe it's because it has steel syncros in those gears instead of brass. The 6sp in my 2013 981 is silky smooth. It's the best I have ever driven.
3rd Gear
Thanks, guys! I've now driven it and don't see any huge issues. It's tighter shifting than some of my other cars, but there's no grinding, nor does it pop out of gear. Nice car! It replaces a classic Mini, which I have listed for sale. but it's certainly a lot easier to steer and to drive. Hard to believe this car is 16 years old!
If it hasn't been done or you don't have paperwork it has been done arrange for a brake fluid (and clutch fluid) flush and bleed. This is scheduled to be done every 2 years. While my experience in letting this go -- just lost track of time -- around 2.6 years didn't notice any issues with the braking system the clutch hydraulic system was acting up. The clutch was hard to engage smoothly and shifting was crunchy. After the fluid service clutch engagement was once again smooth and shifting lost the crunch.
This might not probably won't address a tight shifter but it can certainly help the drivability of the car and help prolong the clutch and transmission life. That crunchy shifting could only have accelerated transmission wear.
Also, I had the transmission/diff fluid changed in my 2002 Boxster at between 60K and 90K miles. I had this done at the dealer: Labor was 0.3 hours. Fluid was a bit pricey but at 317K miles the transmission was still fine so the fluid appears to be up to the task. A few dollars for fluid vs. a few thousand dollars for a transmission rebuild? I know what I'd do.
Another possibility is the shifter itself is worn, though that usually results in play, but can effect the feel of shifting to a degree. Another shifting issue culprit often times is the engine mount. On an 02, assuming it is original, it is most likely shot. The rubber of the mount fails. My 02 S had 56k on it when I bought it and when I removed the mount the rubber encased mount fell out of the carrier. That’s NOT supposed to happen. I also upgraded to a 997 shifter and shifting is excellent now. Still notchy (it’s a Porsche transaxle) but excellent. 2nd gear is notorious for being notchy/tight when cold too. I also suggest a fluid change to Porsche fluid unless you know it was done recently.
