99 BOXTER TOP LATCH
2nd Gear
WHEN I PUT THE TOP UP ON MY CAR, AND ENGAGE THE LATCH THE WINDOWS ONLY GO UP HALF WAY. I THINK I DISCOVERED THE LATCH DID NOT FULLY ENGAGE. I PUT A FOLDED PIECE OF PAPER IN THE LATCH AND THEN ENGAGED IT AND THE WINDOWS CAME ALL THE WAY UP. IT SEEMS THAT WHEN THE LATCH CLOSES IT DOES NOT FULL ENGAGE. WHAT SHOULD I DO?
2nd Gear
I had the same problem. I like how you worked around it, but you need to fix it right
