"The Bird" is now a duck! quacking noise - driver's side
We replaced almost all of the suspension last fall including new coffin arms and the PO just put fresh brakes on the car. Tomorrow i'm going to pull the front wheels and have a look.
the noise only happens at low RPM and vehicle speed. I'm guessing maybe a CV boot or a wheel bearing but I have never heard either of those parts make this duck-lick quacking sound.
Very difficult to look and feel cool with your Porsche quacking like a toy rubber ducky!
suspension dropped one side
After getting the bird onto level ground I could see the suspension on the driver's side is about 1/2" lower than the passenger side. I can't fit two fingers between the driver side tire and the top of the fender lip but have room to spare on the passenger side. What dropped?
OK, seems the ground was not as flat as I thought. Suspension height seems OK side to side. Since the sound follows the wheel speed I am guessing CV and or the CV boot. From the wheel bearing I'd expect more of a grinding noise. The rubber of the CV boot is what I think might be "quacking". Breaker breaker one nine... anyone out there got their ears on? This is rubber duck!
Even if you find all the CV boots in good condition you can spin the wheels and check for any abnormal or difference in noise or feel or effort compared to the other wheels. Check the front wheels too..
Check for a bad spot in the tire or something in the tire, too. Also, I have had a loose under body plastic panel make a goofy noise so check all the under body panels are secure. They might look ok with the car stationary but at speed air flow can cause the panel to rub against a tire, a wheel, or the ground.
