Sports suspension question.
I'm ready to order or buy a new Boxster S. (Hopefully tomorrow.)
Does anyone know anything about the Sports Suspension? Is it too harsh for everyday or is it only slightly firmer than the normal chasis?
I'm considering the Boxster S Special edition and from the web site it seems like it has a sports chasis.
Here's the quote: "True roadster character is emphasized by lowering the body by 10 millimeters and by especially sporty suspension settings. This sports suspension improves the car’s roadholding still further and permits higher lateral acceleration values."
I don' have access to a car with the sports suspension but I have driven a Boxster S.
Thanks,
Charlie
Thanks,
Charlie
I had the sport suspension and it was fine, but I replaced it with the ROW M030 for lower ride height and more compliant ride. If you think you might do that as well, then just get the base suspension and upgrade it to ROW 030, otherwise if not, then sport suspension is fine.
IMO,
The sports suspension is a good bit firmer than stock. I wanted to be able to "sportingly" (if that's a word) handle the back roads of Va, Md, and WV, plus drive into DC & Baltimore from time to time. I tried a mix of firmer suspension components & larger wheels, and settled on "stock" for the suspension and 18" wheels. While the stiffer suspension felt great on the back roads, it simply didn't work on the less than decent streets of DC....
Ghost makes an excellent point - 030 with lowering (ride height closer to the center of suspension travel) is much better than 030 w/o lowering (ride height near the top of suspension travel - leads to bottoming out/hitting the bump stop).
Enjoy the Boxster!!
J
Enjoy the Boxster!!
J
I just ordered my Boxster S Anniversary Edition today. It shoudl arrive in March or April.
I don't think the sports suspension they mention is the 030. I thinks it's just a lowered suspension. Anyway, time will tell.
Thanks for your input.
Now I wait...
Charlie C
Now I wait...
Charlie C
I have 030 (USA specs). I find the suspension is just fine for our roads (Birmingham actually has great road quality). I agree with Ghost though - the lower ride height of ROW 030 is desirable.
Congrats on the order. I think the Anniversary Edition looks great!
Charlie
Sean,
You're quite fortunate there - B'ham area had much better roads than I expected!
Sounds as if there's a bit of confusion here... the suspensions available are:
Standard USA
Standard ROW
030/sport USA (stiffer than standard, same ride height)
030/sport ROW (10mm lower)
More than once the data on ROW suspensions have "leaked" into the USA specs - but unless they've gotten a DOT waiver, the "sport suspension" equipped Boxster will come to the US at the standard USA ride height.
Sounds like a great Boxster!
J
Standard USA
Standard ROW
J
If it's just a height difference, how is that achieved?
Charlie
