Boxster & Boxster S (986) Forum 1996-2004
Replacing Shifter Cables
Old 02-22-2018, 10:30 AM
marshcat
marshcat's Avatar
Default Replacing Shifter Cables
The shifter in my '03 Boxster has gotten a little stiff moving left-to-right. I took the car to my local Porsche specialist, and they confirmed the shifter cables need to be replaced (among many other repairs on my to-do list). I acquired a nice set of gently used cables on eBay, and also located a plastic shifter lock tool.
I am planning on replacing the cables this Saturday. Any tips or tricks I should know before diving in? Any suggestions on the best way to get the new cables perfectly adjusted?
thanks!
Old 02-25-2018, 03:43 PM
bloomjbmw
bloomjbmw's Avatar
Default Cable replacement
thanks!
I have the same experience going on and I’ve debated doing the cables. Are you going OEM or Numeric Racing? If you do have any tips or make a DIY I would like to see it.
Old 02-28-2018, 12:57 AM
mtgadbois
mtgadbois's Avatar
I replaced the cables on my 2000 Boxster S and as I recall it was rather straight-forward. No problems or tricks needed.
Quick Reply: Replacing Shifter Cables
