battery drain
How are you measuring this draw? For how long are you measuring this?
It can take some time after one shuts of the doors and locks the car before the engine controller and other electronics are in their lowest power state.
While my 2002 Boxster goes into a pretty low power mode almost immediately after I lock the car my 2003 Turbo continues to draw some considerable amperage -- I don't recall the amount now but it is quite a bit -- for some time after the engine is shut off, the key removed from the ignition, the doors closed and the car locked. Part of this arises from something (the engine controller most likely) monitoring engine compartment temperature and turning on the engine compartment fan if the temperature climbs too high. My Turbo's engine compartment fan can run even if the car is locked. I believe your 2004 can also run the engine compartment fan with the car locked. My Boxster can only run the fan if the car is left unlocked. If I lock the car I don't believe I have ever noticed the engine compartment fan coming on even in extremely high ambient temperatures.
Car locked, car sitting there, next day ammeter between neg cable and post, draws .4 amps, If we remove c-1 drops to .02 amps. Should be .05 or less I would think. Hence c1 circuit is the problem. Thanks for the guidance
