Backwards Battery Hook-Up
Hello all,
As title states I got a 1999 Boxster in today with a battery hooked up backwards. Replaced battery with new one hooked up correctly. I get all lights as well as interior and dash lights to come on. When ignition turned to start I get no start nor click. Ive replaced all blown fuses in driver footwell and checked the large fuse in rear trunk. Whats fried causing the no start? What else can I check?
Thank you for any help in advance.
My guess is that the starting problem came up before the battery swap.
I would check the clutch switch and ignition switch. Both inexpensive and easy to replace if you are a contortionist.
See if moving the key around while you turn the key to start the engine makes a difference. IOWs the ignition switch is suspect, even though the dash lights come on.
Check the security module located I think under the driver's seat. IIRC it has a fuse and if so and its blown the security module is getting any power and when the key is turned can't query the key for its RFID.
A co-worker's husband connected a battery backwards in his BMW -- this maybe 5+ years ago and the BMW wasn't a new model then but it still had lots of electronics/electrics -- and the only thing that happened was the speedo needle went around and was underneath the support pin. His solution was to drill a tiny hole in the plastic instrument cluster covering and carefully pick the speedo needle up with a metal sewing needle and put it back up where it belonged.
Not as far back as 5 years I seem to recall a thread here in which someone hooked up a battery backwards and the damage was slight.
Still hooking up a battery backwards is something to be avoided. I hope the OP is able to sort the car out.
