Stereo Wiring
6th Gear
Stereo Wiring
I'm sure this has been posted here, but I cannot find it. Simple question, I want to run four RCA cables from my head unit to an amp in the front trunk. What is the best path that should take?
Thanks,
Paul
Thanks,
Paul
6th Gear
Years ago when I bought the car, I put in a Kenwood DNX6990HD. Works wonderfully for XM and Garmin. It uses the Crutchfield harness to connect to the factory amp. Not the highest sound quality. I plan to replace the factory amp.
There is an access point with a rubber boot ring in the well above the left side (drivers side). It can be seen from the front looking to the right of the battery against the firewall. It will be round and about 1 1/2" in diameter.
You can poke through that and run what is necessary to the frunk.
