Now that there's support for running Option Code XRR wheels on a 2006 CS, which ones?
In preparation for competing in A-Street starting January 1st, 2014, as well as taking advantage of the new +/- 1" wheel diameter allowance, I've bought two used sets of 18x8.5/18x10 O.Z. Alleggerita wheels over the past six months.
Both sets use 18x8.5 ET53 front wheels, but one pair of 18x10 rear wheels is ET40 (Cayman/Boxster fitment) and the other pair is ET65 (911 NB fitment), so that I can tweak the final offset using spacers, because I like the flexibility of being able to run a narrower track on slower and/or tighter courses or on courses with a lot of slaloms.
Although the Alleggeritas are reasonably priced and reasonably light, I'm not particularly wild about their styling, although they're not so ugly that I can't live with them if I absolutely must:
![](http://audidudi.site90.com/photo.jpg)
That said, they're also a few pounds heavier than I would prefer, which will be a bit tougher for me to live with, as I tend to be OCD about weight, especially unsprung weight. (FWIW, with AD08 tires, my same-width 19" Champion RG5s are a whopping 17 lbs lighter for the complete set of four than my 18" Alleggerita/ZII combo ... and IMO, they're much better looking, too!)
![](http://audidudi.site90.com/_DSF3248b.jpg)
The obvious solution is for me to buy a set of 18" RG5s, but I've had no luck finding a used set and unfortunately, a new set is way beyond my budget limit ... for now, anyway.
So I've started pondering less costly alternatives (assuming, of course, that I ultimately do decide to switch to 18" wheels, as my initial testing has shown the 19" wheel/tire combo to be consistently a few tenths of second quicker) and I am curious as to which wheels other Cayman/Boxster owners will be using.
Comments, thoughts and/or suggestions?
Hmm ... TWS Motorsport's T66-F forged wheel looks quite interesting. Made by the same Japanese manufacturer that makes Champion's wheels, the 18x8.5 ET48 wheel weighs 7.32 kg (16.1 lbs) and the 18x10 ET60 wheel weighs 7.76 kg (17.1 lbs): http://www.tws-forged.com/tws_t66-f.html. This is approx. 10 lbs per set lighter than the O.Z. Alleggerita and the offsets are a bit more optimal to boot. (For a bit more money, custom offsets can be specified, but it appears there is a minimum order of four sets ... I'll look into this.)
At today's exchange rate, the 18x8.5 wheel is $680 per and the 18x10 rear wheels are $710 per, which is roughly $1k more than a set of Alleggeritas ... as I said, hmm. I wonder if there's any potential for a group buy here?
So far, the Forgestar F14 wheels are proving to be the least expensive option, at $1,359.95 for a set of four: http://www.modbargains.com/Forgestar...he-18-Inch.htm.
The claimed weights are both ~.8 lb heavier than the O.Z. Alleggerita (18.5 lbs for an 18x8.5 ET48 front wheel) and about the same amount lighter (19.4 lbs for an 18x10 ET42 rear wheel), but custom offsets can be specified for no extra charge, which is a big plus, IIMO. I like their styling, too.
(Per the internet, early wheels had some QC issues, but a friend who has one of the early sets on his BMW has had no problems with his, so YMMV. In any event, the manufacturer claims those issues have since been addressed...)
Don't the current SCCA stock class rules dictate that offset be no more than +/- 0.25 inch from OEM specs? I believe this rule carried over to the new street class. Not sure what your stock offset is, but the difference between the two OZ rear wheels you bought is 25mm or almost an inch.
As I understand it, this change was made to accommodate cars that come from the factory with spacers (or have them as an available option, as many Porsches do) so their owners have the option to run one spacer that combines the width of the factory spacer plus any amount of the SCCAs +/- .25" offset allowance instead two separate spacers, no spacers at all by choosing wheels with an appropriate offset, or some combination of the two (which is what I chose.)
In the case of my Cayman S, because the OEM offset for the 19x10 wheel is 42mm, this means that any net offset between 35.66mm and 48.34mm is legal per the +/- .25" allowance. If one wishes to also use the 5 mm spacers that were an available factory option for this car (option code XRP), then the allowable offset range becomes 30.66mm to 43.34mm.
Of course, since the factory spacers were used on all four wheels, not just the rear wheels, the allowable offset range for the front wheels also changes (in this case, from 48.66mm to 61.34mm without the factory 5mm spacer to 43.66mm to 56.34mm with the spacer.)
Thus, my 18x10 ET65 rear wheels, combined with a 22mm spacer, have a net offset of 43mm and therefore fall well within the allowable range...
Well, as it happens, I have found (and purchased!) a used set of hard-to-find Cayman/Boxster fitment 18" Champion RG5 wheels (18x8.5 ET50 / 18x10 ET38), so the wheel search I was documenting above has now come to an end. (I paid a bit more than I would have liked, but as this was only the second set I've seen for sale in over a year of diligently crawling around the 'net looking for them, I sucked it up and paid the seller his price...)
As a heads-up, in case anyone reading this might be interested in one or both of them, I will be posting both sets of my O.Z. Alleggerita wheels for sale shortly...
Where do you think your 19" combo is making the time improvement vs. your 18's? Aren't the 19" tires even taller than the 18's? I remember over 10yrs ago when the first ultra low profile 18in hoosiers came out (285/30) what a radical improvement in steering and cornering feel and precision that was, are 19's going to be the same? (cost, and sizing issues put aside).
