autocross alignment specs for 98' boxster
Can someone give me an idea of alignment specs for autocross on 98' boxster? Also what tire pressures for autocross front and rear?
Max Out front negative camber (you might get -0.8 or something around), be sure it is even on both sides. At the rear run the less camber possible (rear goes from -1.0 to -2.0 run the closest to -1.0 even on both sides).
Toe: 0 toe at all corners.
Hit gas and stay on the gas as much as possible, try not to lift, the car is fun. I had a 01 Boxster S, and a 99 Boxster 2.5, they were fun cars.
For RS3, I would start at 36 psi hot all around, and drop to 32 psi on the axle that needs more grip (typically the front axle, as Boxster pushes).
This is a good baseline, then fine tune from these specs.
