Need 17" tires Hankook RS3 or Toyo R1Rs?
Both of these cost as near as makes no difference the same.
Both cost about the same number of points (treadwear 140)
I will need to use to drive 2 and from events so I can't go full slick
Any thoughts? preferences? experiences?
Hard to go wrong it appears...
My car is a stock 2004 996 40th Anniversary ed. I autocross about 6-10 times a year. I have been autocrossing (various cars) for about 3 years. I am not competitive in my class, but hope to be some day.
I have not driven either, but both are well regarded in street tire AX classes.
You might have a read of this:
http://www.facebook.com/notes/hollis...45008598916447
Probably more than you want to know about street tires for AX, but there is some great stuff in there.
Brian
Brian
I appreciate it... The Kumho XS are just a bit cheaper. And "cost" the same in point deductions, so they too are an option.
FWIW they look like they might last just a bit longer as well... which is always a bonus
I have been on R-S3's all season and have done very well in CS. I have straight up beaten r-comp equipped cars in CS this year or been within 1 second of them at every event except one. During our 7th event of the year, the temps were high on course and i was having trouble with front traction in my '98 Boxster (OEM front tire size) in the afternoon. After the event I had the tires flipped (outside is now inside) and this past weekend with even hotter temps, did well again. I plan on replacing the tires after the season is over and will use these tires as extra street tires.
Yes, I drive to and from the events on the R-S3's.
I lurk over on the SCCA Forums and saw something regarding the Kooks that may be of interest.
SCCA has just decided that starting in 2013, the new Road Tire classes will require a TW rating of 180 or higher. That effectively bans the Kooks and the Toyo R1R from the Road Tire classes.
http://www.sccaforums.com/Forums/tab...s/Default.aspx
Note that this is relative to the new Road Tire classes not the Street Tire classes that have been in existence for many years.
Brian
Brian
One thing to be aware of is that the R-S3s need to be hot to work well -- they're bad in cool weather and disastrously bad in cold weather. This may not bother you since you live in San Diego, but you should at least consider it. Dunlop Star Specs are far more tolerant of cool temperatures, and the R-S3s are not consistently faster than the Dunlops are...
Brian
Brian
I once thought that TW was relevant within the same manufacturer, but now I even doubt that.
One interesting aspect of their going to 180 is that the N Spec Bridgestones that came stock on my Cayman S are 140. So, if someone shows up with a box stock Porsche wanting to run in the RT class will not be able to.
I don't have a dog in the fight, since I rarely run with SCCA and if I did, my AX "street" tires are the AD08's at 180, but it seems that the real goal was to kill the Toyo, and the Kooks were just collateral damage. I guess no one wanted to use the tire exclusion list for its intended purpose.
Brian
My car is a stock 2004 996 40th Anniversary ed. I autocross about 6-10 times a year. I have been autocrossing (various cars) for about 3 years. I am not competitive in my class, but hope to be some day.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
As others have mentioned, if you ever desire to autox with the SCCA in the RTR stock class, I'd avoid the toyo / hankook tires as they are now illegal.
I am not with the SCCA; the PCA is who I autocross with. In addition to treadwear, they add points on width. You get 205 /225 (430 total points) for free.. any width over that is classification impacting.
I switched to sticker, lighter tires that only "cost" a few more points than stock. So I stayed in my normal category.
I also get dinged for the LSD and horsepower bump, even though they are factory.
Although the 18s on the 40th AE are wicked light (for 18s). I have some lighter 17s and plus this gives me the flexibility to have my nice wheels for nice days and the other set for AX days. Plus, 17" based tires are almost always less expensive and lighter.
