Car tie down to trailer
Not new to autocrossing or trailering but recently bought a 2010 turbo and am looking for suggestions on the best method to tie the car down to my open trailer. With my former car (corvette) there were transport slots that were very handy for that purpose. Any suggestions would be greatly appreciated!
Don't use wheel straps, the heavyweight car, lateral movement when towing, plus the aluminum subframe will mess up your alignment.
If you use those jack points, do not over tighten them and always check the condition of those. Mine are only spot welded in 3 or 4 places to the car. Hardly a very strong point on the car for horizontal shearing loads. My mechanic has seen plenty of newer Porsches that have had these points completely or partially torn from the car from overzealous strapping.
I use rear chassis tow hooks from Rennline and at the front I use wheel straps until I can make my own front chassis mounts. The front wheel straps are going to D-rings I had welded directly in line with the centerline of my front tires.
Cheers,
Cheers,
First off I have had a lot of problems with T hooks falling out of the jack point holes. Also I have towed my car over 6000 miles using wheel straps and have not had alignment changes ( I check the toe once every 2 months during the season ). If the wheel straps were causing alignment changed I would not use them.
Thank you for the responses, much appreciated.
On a different note, any concerns about putting A6s 265 up front and 315 in the rears as they are the same diameter? Also any suggestions on tire pressures for the A6s?
Cheers
Kim
Cheers
Kim
