New 19" R compound from Hoosier
If you go to Hoosiertire.com they have the new compounds and sizes posted. Looks like a close size for the 997 GT-3 that will fit on the 19 X 12 rears.
46300 P185/60ZR13 M 6.9" 21.7" 68.2" 6-7" 6.0" 7.8" X
46305 P205/60ZR13 M 8.0" 22.8" 71.7" 5.5-7.5" 6.0" 8.8" X
46307 P225/45ZR13 M 8.5" 20.9" 65.8" 7.0-8.5" 7.5" 9.3" X X
46310 P225/50ZR13 M 8.5" 21.9" 69.0" 6-8" 7.0" 9.4" X X
46405 P205/55ZR14 M 8.1" 22.8" 71.6" 5.5-7.5" 7.0" 9.1" X X
46410 P205/60ZR14 M 7.8" 23.6" 74.2" 7-8" 6.0" 8.2" X
46415 P225/50ZR14 M 8.8" 22.9" 72.0" 6-8" 7.0" 9.4" X X
46500 P205/50ZR15 M 8.0" 22.8" 71.7" 5.5-7.5" 6.5" 8.7" X X
46505 P215/60ZR15 M 8.3" 25.2" 79.1" 6.0-7.5" 7.0" 9.2" X
46510 P225/45ZR15 M 8.8" 22.9" 72.0" 7.0-8.5" 7.5" 9.8" X X
46515 P225/50ZR15 M 8.8" 23.8" 74.8" 6-8" 7.0" 9.8" X
46520 P225/55ZR15 M 8.7" 24.8" 78.0" 6-8" 7.0" 9.6" X
46525 P245/50ZR15 M 9.2" 24.8" 78.0" 7.0-8.5" 7.5" 10.1" X
46535 P275/35ZR15 M 10.1" 23.0" 72.2" 9.0-11.0" 9.5" 10.8" X
46540 P275/50ZR15 M 10.0" 25.5" 80.0" 7.5-9.5" 8.0" 10.8" X
46600 P205/45ZR16 M 8.0" 22.8" 71.7" 6.5-7.5" 7.0" 8.7" X X
46610 P225/50ZR16 M 9.0" 24.7" 77.6" 6-8" 7.0" 9.5" X X
46615 P245/45ZR16 M 9.2" 24.7" 77.7" 7.5-9.0" 8.0" 10.1" X X
46620 P255/50ZR16 M 9.8" 26.2" 82.2" 7-9" 8.0" 10.5" X X
46630 P275/45ZR16 M 10.3" 25.6" 80.5" 8.5-10.0" 9.0" 11.2" X X
46700 P205/40ZR17 M 7.0" 23.8" 74.8" 7-8" 8.0" 8.5" X
46705 P225/40ZR17 M 8.9" 23.8" 74.5" 7-9" 7.5" 9.8" X X
46710 P225/45ZR17 M 8.8" 24.7" 77.7" 7.0-8.5" 7.5" 9.7" X X
46715 P245/40ZR17 M 9.3" 24.5" 77.0" 8.0-9.5" 8.5" 10.0" X X
46720 P245/45ZR17 M 9.4" 25.7" 80.7" 7.5-9.0" 8.0" 9.9" X
46725 P255/45ZR17 M 9.8" 26.2" 82.2" 8.0-9.5" 9.0" 10.8" X X
46730 P275/40ZR17 M 10.3" 25.5" 80.1" 9.0-11.0" 9.5" 11.0" X X
46733 P295/35ZR17 M 10.8" 25.3" 79.5" 9.5-11.0" 10.0" 11.6" X X
46735 P315/35ZR17 M 11.6" 25.6" 80.4" 11-12" 11.0" 12.6" X X
46740 P335/35ZR17 M 12.9" 25.6" 80.5" 11-13" 12.0" 13.6" X X
46810 P225/40ZR18 M 8.8" 24.8" 77.8" 7.5-9.0" 8.0" 9.5" X X
46820 P245/35ZR18 M 9.1" 24.7" 77.7" 8.0-9.5" 8.5" 9.8" X X
46825 P245/40ZR18 M 9.3" 25.7" 80.6" 8.0-9.5" 8.5" 10.5" X X
46830 P255/40ZR18 M 9.8" 26.2" 82.1" 8.5-10.0" 9.0" 10.6" X
46835 P275/35ZR18 M 10.3" 25.5" 80.2" 9-11" 9.5" 10.7" X X
46840 P285/30ZR18 M 10.9" 24.9" 78.1" 10-11" 10.0" 11.5" X X
46843 P295/30ZR18 M 10.8" 25.3" 79.5" 9.5-11" 10.0" 11.6" X X
46846 P315/30ZR18 M 11.6" 25.6" 80.5" 11-12" 11.0" 12.5" X X
46850 P335/30ZR18 M 12.9" 25.6" 80.5" 12-13" 12.0" 13.5" X X
46855 P345/35ZR18 M 12.8" 26.8" 84.3" 11-13" 12.0" 13.9" X X
46915 P235/35ZR19 M 9.25" 25.6" 80.5" 8.0-9.5" 9.0" 10.2" X X
46925 P265/35ZR19 M 9.6" 26.1" 82.3" 9-10" 9.0" 10.4" X X
46935 P295/30ZR19 M 10.4" 26.1" 82.1" 10-12" 10.0" 11.5" X X
46940 P315/40ZR19 M 11.3" 28.9" 90.7" 11-12" 11.0" 12.9" X X
46945 P325/30ZR19 M 12.2" 26.8" 84.1" 12-13" 13.0" 13.6" X X
46950 P345/30ZR19 M 12.9" 26.8" 84.3" 12-13" 13.0" 14.1" X X
NOTE: DOT labeled Hoosier Racing Tires meet Department of Transportation requirements for marking and performance only
and are NOT INTENDED FOR HIGHWAY USE. It is unsafe to operate any Hoosier Racing Tire including DOT tires on public
roads. The prohibited use of Hoosier Racing Tires on public roadways may result in loss of traction, unexpected loss of vehicle
control, or sudden loss of tire pressure, resulting in a vehicle crash and possible injury or death.
NOTE: Z Speed Rating = above 149 mph/240 km/h. Consult Hoosier Racing Tire for maximum speed.
TREAD PATTERN PICTURES AVAILABLE ON INSIDE BACK COVER.
INDEPENDENT DEALERS MUST ESTABLISH THEIR OWN PRICES.
FOR PRICING CONTACT YOUR NEAREST DISTRIBUTOR (SEE PAGE 16).
REFER TO INSIDE FRONT COVER FOR NO WARRANTY POLICY AND WARNINGS.
The 265/35 and 325/30 are a possible fit for the Carrera. They could be squeezed on the OEM wheels by a determined tire mounter, and would fit well on the optional 19x8.5 and 19x11.5 rims. The question is, will there be rubbing and is there a downside to the slight gearing change and 9-10mm higher ride height with those wider, taller tires?
I'd be concerned that on a GT3, the combo of 235/35 and 325/30 would require some aggressive and somewhat self-defeating sway bar adjustments to avoid understeer, namely, more rear bar. I'd try to match the 325 with a 265 on the front.
- Ted
- Ted
