Bridgestone Re-71RS
#31
Quit Smokin'
Trying out a set or two of tires is not Tire Testing in my book. Maybe it is yours and might explain a bit but I won't waste my breath discussing this with you. Go to SSR, get your *** handed to you and look for some reason why you didn't get the result you were looking for. You obviously know everything, and feel that autocross is a waste of money.
#32
AFAIK SSC was wished into existence straight from either the SEB or maybe even the BOD. With the popularity of the class, I wouldn't be completely shocked should another one show up. I'd likely be a quite different car though should it happen, I dunno. Could always put a bug in their ear to try a 2nd SSx class based on the success of the first. A 981 with GT3 control arms and 18s would be nice but don't think there's enough out there who would run it. Nor does that get people to buy a special modification package only available at Tire Rack.
The following 2 users liked this post by burglar:
bpstanaway (09-20-2022),
daaa nope (09-20-2022)
#33
The part in red...... That's tire testing. That's possibly a few alignments, a few sway bars, a few test days, a few wasted events. That part is literal waste. it's not helping anyone except Tire Rack. You know everyone is doing it, and you won't call a spade a spade.
Current street tires are still more economical $/run then hohos and if you decide to not run on your test tires for locals they’re typically easily sold to someone else in your neck of the woods. Certainly not everyone is doing it, we bought two sets of yokes and two sets of Bridgestones, plan is to wear them all out so we still get our moneys worth out of the tires, killed the first two sets pre nats, will run the next two into the spring.
The following 2 users liked this post by bpstanaway:
daaa nope (09-20-2022),
RacingChris44 (09-21-2022)
#34
I was at Lincoln and only brought Yokes. Must be doing it wrong
The following 3 users liked this post by justint5387:
#35
Quit Smokin'
It was obvious from results that any of the 3 (yoks, stones, falkens) can win, just pick one and stick with it.
The following 5 users liked this post by justint5387:
Abt12 (09-30-2022),
BmacIL (09-21-2022),
bpstanaway (09-21-2022),
WillyDaP (06-28-2023),
Z3papa (09-21-2022)
#37
Some platforms/classes it was more skewed than others, but yes, all three tires are clearly quick enough to win. Cars on double wishbones that need help putting power down generally see a pretty sizeable advantage on Yoks, especially on Lincoln's concrete. Camber-limited and/or front heavy cars generally did better on Falkens or Bridgestones.
#38
Buying one set of tires, say Rt660's, at the beginning of a season and either borrowing or buying a second set (Yoks/Nankang or now Bridgestone) later in the year ostensibly in anticipation of Nat's, isn't testing in my book. I don't even think that having two sets of tires/wheels and spinning some laps on the Nat's practice course (which is typically not representative of the competition surface run on) is really worthwhile testing but it's better than nothing if you want to see which tire works best for your car setup on that course. Using Nolan as an example, as much as I believe the new Stones are a better version of the RT660, I know Dave doesn't drive using controls. His ego gets into the mix (as is the case with most folks hitting the practice course) and is prone to try a flyer on the practice course even knowing he'd hit cones just to flash a faster raw time to other potential competitors watching or running the same time slot. It's kinda like the guy who will jump in someone's car during fun runs, lay down a blistering time with no pressure, hit a cone or two and walk off saying he would have won if he were driving that car, that day, with that competition. OK yeah right. That's why guys like Andy and Whitener aren't just slapping tires without real controls for their GRM tests as they would be scrutinized even more. They use the same damn course over and over with same cone markings as a base control so that course familiarity doesn't skew results. I suspect strongly that the vast majority of folks assess their cars strengths (suspension geometry and putting power down) and weakness (lack of camber or tendency to under/oversteer) and decide which tires best suite their car/their driving style, and then work to making their cars as fast and predictable as possible.
#39
BmacIL (09-21-2022)
#40
A competitor of mine tried 4 different combinations of Yoks and 660's, new, mid-life, etc. on the practice course on a BS Supra. He and his jacketed co-driver found no time difference for any of the combos. They ran Yoks in the competition. That was a good choice, as the Yoks accumulated much less OPR, according to a friend that cut OPR for both of us. (I was on 660's.)
#41
OPR?
Other People's Rubber... like pickup?
#43
#45
