04 996 Aftermarket Radio
Looking for a referral in northern NJ area to replace OEM radio and speakers with a kenwood headunit. All the shops I've contacted have no experience with the MOST system or suggested a complete rewiring which isn't an option. Thanks!
I found a place shortly after posting inquiry. Sound Waves located in Parsipanny NJ says it requires replacement of headunit and amplifier as you stated. They specialize in Porsches. I'll let other 996 owners know how it goes.
Yeah, they will simply eliminate the MOST cable, and hopefully use that connects the output plug from the stock amp to the aftermarket amp and HU. Otherwise they just lop off the factory plug from the amp and splice the speaker outputs in.
Yeah, they will simply eliminate the MOST cable, and hopefully use an adaptor plug that connects the output plug from the stock amp to the aftermarket amp and HU. Otherwise they just lop off the factory plug from the amp and splice the speaker outputs in.
Yes, 2 ohm and in fac apparently 1 ohm for Bose subs. I am no expert but my reseach indocates that damage can occur over long term. Any good installer will be aware of this and supply you equipment or instalation to suit.
