Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
Nav-TV (991)
Old 07-15-2015 | 10:11 PM
Cpages2's Avatar
Cpages2
Default Nav-TV (991)
So I purchased the PCM-3.1 XG-Cam System for my 2013 911 C2
https://navtv.com/products/NTV-KIT375/pcm31-xg-cam.html
Had it professional installed however I seem to be having two odd issues that other installed members (even using the guide on 6 speed online) say they dont have.
1) When I go into D from R (PDK) the camera goes off immediately, reading the install post and others they all say their favorite feature is the camera stays on for a few seconds when moving forward.
2) When I am in the Car Settings screen and go under Backup Camera and choose show screen I just get a black screen that says OBSERVER SURROUNDINGS. It does not show the video.
Any help or insight would be awesome!
Thank You!
Old 07-16-2015 | 02:40 AM
DWPC's Avatar
DWPC
Sounds to me like the camera may be wired to the back-up lights for power, instead of to an ignition-switched circuit to have power whenever the ignition's on. If that's the case, it can't send an image unless you're in R. This would also explain a dark screen if the "Observer Surroundings" setting is for the rear view when not in R. Try it with power from an ignition-switched accessory circuit like the TPMS fuse. If that fixes it, it was improperly connected and the installer should correct it. It may also be a wiring issue with the Reverse sensing lead in the harness.
Old 07-17-2015 | 08:13 PM
Cpages2's Avatar
Cpages2
That was it! Place fixed it today. Thank you!
Quick Reply: Nav-TV (991)
