Becker Cascade Pro advice.
Evening guys, took me a while but eventually tracked down the above unit which looks great fitted to the 944 S2. Photos to be uploaded later.
It acme from Germany and everything works as it should except the navigation, I have everything loaded, I have satellites showing and I can enter a destination but that's where it all stops.
It does not proceed to load destination or give me directions. Once installed it did not ask to do a calibration run.
I read somewhere that the GAL and reverse signal was not needed for the navigation, is this indeed the case? Do I need to connect these in order for the Navi to work? Any advice would be much appreciated.
Many thanks
Paul.
Many thanks
Paul.
