Trying to buy a Blaupnkt Toronto 420 BT.... anyone know dealer whom sells blaupunkt?
I have ordered one from amazon but it said the product is not available....blaupunkt in Germany said its been out for 6 weeks (they sent me an email) But i cant seem to find any blaupunkt dealers...
anyone know where I can order a Toronto BT 420 by Blaupunkt stereo?
Blaupunkt are a pain like that. I have had a look here in NZ and can't find one.
I recently went through this and ended up buying a Becker Gran Prix. Amazing head unit but also hard to find.
I know the guy in Germany I got mine from still had one when I last looked. If you want his details let me know.
The becker is a seriously high quality unit, and still made in Germany, unlike Blau.
Cheers
Cheers
One on ebay:
http://www.ebay.com/itm/BLAUPUNKT-TO...91b6b6&vxp=mtr
I bought a Toronto 410 about a year back from ebay for ~$200 shipped, been very happy with it. I did need to install the external mic on the steering column though, BT clarity is very good as a result.
Amazon now has the Blaupunkt 420BT on line, decent price as well. ($135, free prime shipping).
Just ordered one to replace the CDR23 in my '03 996, along with the Blaupunkt EMA 455 amp.
![](http://www.blaupunkt.de/uploads/tx_ddfproducts/Toronto_420BT_01.jpg)
pfbz - hope you are going to change out the speakers. If you have the Bose system the speakers are 2 ohms, and I doubt the amp you ordered can handle the 2ohm speakers at its output. Do yourself a favor and look into it, before you change out.
I don't have the Bose system. Base audio, no amp, no door speakers, nothing but the original 4.5" speakers in the dash and sides of rear seats. Really pitiful speakers... paper cones, foam surrounds, very light magnets, not even a whizzer cone. 4-ohm
So yes, I'm changing the speakers...
I'll probably try a few different setups, but Best Buy had some Polk 4" plate speakers on sale for $70/pr last week so I picked up a pair and cut/fit them into the stock grills.
I'm going to post the stereo/speaker install in a seperate thread, but here's a few shots of the speaker mod.
Stock speaker:
(rear on left, front on right. Fronts have identical drivers but slightly different grills which angled the speaker cones towards the cabin)
![](http://photos.smugmug.com/photos/i-73gNhsp/0/M/i-73gNhsp-M.jpg)
Polk 460P, trimmed and installed on stock grille.
![](http://photos.smugmug.com/photos/i-ffR43r3/0/M/i-ffR43r3-M.jpg)
![](http://photos.smugmug.com/photos/i-cpbbjgX/0/M/i-cpbbjgX-M.jpg)
![](http://photos.smugmug.com/photos/i-sNSkstx/0/M/i-sNSkstx-M.jpg)
![](http://photos.smugmug.com/photos/i-rqcrPhf/0/M/i-rqcrPhf-M.jpg)
Completed, looks 100% OEM.
Fit fine in the dash. Even reused the Porsche speaker connector.
![](http://photos.smugmug.com/photos/i-tRsnLTq/0/M/i-tRsnLTq-M.jpg)
Stock speaker:
![](http://photos.smugmug.com/photos/i-C5TrSZW/0/M/i-C5TrSZW-M.jpg)
The Penguin King
I just bought a Toronto 410BT (which I guess is an earlier model, though I can't for the life of me figure out the difference between the 410 and the 420) from Crutchfield. I installed it in my 964 Turbo. Looks like it belongs in the car, and works quite well.
Quick update on the Blaupunkt 420 BT.
I purchased one from Amazon, $135 with free 2-day shipping (price is now listed slightly higher at $150).
It's a nice unit, with full bluetooth streaming audio, bluetooth phone, two USB ports, etc.
It has a german like design, fairly simple looking with two ***** and looked appropriate in my 996. It did have blue lighting instead of amber. As you might expect, it is made in China.
Sound quality was good, bluetooth worked well both streaming and phone, the usb worked fine on ipods and an iphone4.
It had a fatal flaw for me, however. I am using an iPad mini for navigation, pandora, slacker, etc. and the Blaupunkt will not connect to an iPad mini through USB (and I assume won't connect usb to an iphone5 either). Probably a firmware issue, might eventually get fixed, but it was a deal-breaker for me.
I replaced it with a Pioneer DEH-X9500BHS for $195 shipped. This is a new Pioneer unit that has two rear USB connections that work perfectly with all the apple devices i've tested, including connecting and properly charging the iPad mini.
It has bluetooth (streaming and phone), HD radio and the ability to control Pandora directly from the head unit if desired. Six pre-amp outs if I want to add amplification, but honestly it sounds pretty good without. I wasn't really looking for amazing high fidelity, rather a modern deck that I could use as a bluetooth phone system and connect/stream iMusic to. Plus my non-bose Becker system *really* sounded terrible. I thought it was the speakers, but after swapping decks, it's the head unit that is the root of my previous audio evil...
The Pioneer looks a bit better than most aftermarket decks in my opinion, a bit simpler with a single, larger volume **** and minimal amounts of buttons. It also allows the buttons and display color to be custom set. I have it pretty close to the Porsche amber, but still tweaking the settings a bit. It also has the CD player slot (which I will never use) behind a flip down face which gives it a cleaner look.
It definitely has some "kiddie" features that I don't care for, like and a bunch of jumping/flashing display garbage, but fortunately you can turn it all off.
![](http://a248.e.akamai.net/pix.crutchfield.com/ImageHandler/fixedscale/400/300/products/2012/32/130/x130X950BHS-o_green.jpeg)
On a side note, I tested my iPad mini with many different decks at different shops... Some of my results:
iPad mini (and presumably iPhone 5) USB connectivity
- Blaupunkt: No connect, no charge.
- Alpine: Connect, no charge (checked at least six different alpines)
- Kenwood: Mixed results... Some connected, some charged.
- Pioneer: Connect & charge on all the newer units I tested.
- Sony: Connect & charge, but a bit of flakyness in operation.
I have a 1997 C2 with a CRD220 and a 6 disc changer. Does anyone know if:
- The CD Changer still work after installing Blaupunkt 420 BT?
- Is the console microphone good enough for hands-free calling, or is the additional microphone a must?
