Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
Basic Amplifier Question
Old Jun 5, 2012 | 09:14 PM
n2cars's Avatar
n2cars
Default Basic Amplifier Question
I have a 80 watt amp. No complaints. Drives the speakers with ease. Plenty of volume. Doesn't run hot. Would there be any "sonic" benefit to upgrade to a 150 watt amp from the same manufacturer?
Old Jun 6, 2012 | 12:16 PM
Bob in NY's Avatar
Bob in NY
Probably not unless your speakers demand more power to manage the dynamic range of the music. It depends on the efficiency of the speakers and the power necessary to drive them. Hope that helps.
Old Jun 6, 2012 | 01:31 PM
aussie jimmy's Avatar
aussie jimmy
upgrade to tubes.
Old Jun 6, 2012 | 03:48 PM
A.Wayne's Avatar
A.Wayne
Formula One Spin Doctor
You will have to give more details to get an intelligent answer, aside, I have never encountered a situation where more power was not benificial ...
Regards,
Old Jun 6, 2012 | 05:44 PM
n2cars's Avatar
n2cars
Regards,
The speakers are Magnepan 1.7. Sensitivity is 86 db... 4 ohm speaker. Magnepans are notorious for needing more power. I'm using a NAD integrated amp rated 80 watts at 4 ohms. I was skeptical that 80 watts would be enough but this little amp seems to be doing the job. I've never used integrated amps before or even amps with this little power. Many years ago I ran Krell 500 watt mono amps with Apogee Diva speakers.
Old Jun 6, 2012 | 06:42 PM
Kevinmacd's Avatar
Kevinmacd
As long as you are not driving the outputs to DC, meaning clipping the outputs, then you are okay. Sonic doffernec I doubt it, since you never get it up in that range anyway
Old Jun 6, 2012 | 06:46 PM
Tonydec's Avatar
Tonydec
If the amp is properly built, i.e. good power supplies, it should be an improvement, even when listening at similar volume levels. It may sound OK now, but popular theory (AKA audio voodoo) says mids and soundstage should improve.
Old Jun 6, 2012 | 10:23 PM
aussie jimmy
you should get improvement in bass, and bigger soundstage. 86db is a hard to drive speaker. over 90db is fine. get a retailer you know to loan you an amp to take home and try it yourself.
Old Jun 6, 2012 | 10:38 PM
LT Texan's Avatar
LT Texan
Originally Posted by n2cars
Many years ago I ran Krell 500 watt mono amps ....
And he is asking us if he needs more watts.
You should be telling us.
Old Jun 7, 2012 | 03:34 PM
Kevinmacd's Avatar
Kevinmacd
Bass is improved with a high damping factor. if the 80 watt amp is not being driven hard at listening levels, bass will not improve going to a higher wattage amp. Especially if this amp has a lot of head room! One other factor @ what band width is the 80 watts stated. In order to double his volume he will need to 10X the amp power!
Old Jun 18, 2012 | 01:57 PM
Dean_Fuller's Avatar
Dean_Fuller
With your set up...short answer is probably yes.
Old Jun 19, 2012 | 09:37 AM
Kevinmacd's Avatar
Kevinmacd
Short answer is probably no!
Old Jun 19, 2012 | 10:58 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Here you go, 800 watts for less than $100
http://www.bestbuy.com/site/Technica...&skuId=4630445
With a 30 day return policy - what do you have to lose?
Old Jun 20, 2012 | 09:06 PM
911Jeff's Avatar
911Jeff
Default less than 3db....
You would gain a little less than 3db in dynamic range and headroom........
Old Jun 22, 2012 | 10:33 PM
A.Wayne's Avatar
A.Wayne
The 1.7 benefits from Power, i have a good friend who had one before upping to a 3.7 , dont use less than 200 watts /8 ohm on this speaker, he was running his with 400 @ 4ohm ( it's a 4 ohm speaker) Maggie's are power hungry current speakers.
You will also have to play with tweeter gain when adjusting to your room, make sure you have resistors handy ..
PS : You had a better system many years ago ...
