Digital music storage
The Penguin King
Yeah, I know, play vinyl...
My ancient CD changer is dead, and it's time to move away from that technology. Any comments on preferred ways to store and play back digital music. I've got a fair mount of stuff on iTunes, have enabled iTunes Match, and a house full of Apple computers, so I'm tempted to just rip all of my stuff to iTunes and store it on the cloud.
Comments? Pros, cons?
Big question is do you care about playback quality? The solutions will vary depending upon whether you don't mind mp3's/high compression rates or require CD quality as a base minimum.
The Penguin King
I want CD quality as a base minimum. Storage capacity and the cost associated with it are not an issue in my opinion, as disk drives and iCloud are cheap. IIRC, iCloud provides you with 256k on everything you load to the cloud regardless of the quality you have.
http://www.wavelengthaudio.com/, make great USB DAC's and are very Mac friendly. You do not want to use the laptop output straight into your preamp. A good DAC set as the default output, with the right volume settings will minimize the affects of the poor gain stage and processor in your laptop.
If you want to use an iPod for playback, the Wadia doc is great, coupled to a DAC. That's at least my experience.
The Penguin King
Thanks, I sort of suspected a dedicated DAC would be in order.
So is this a sane way to go with digital content? I was once an audiophile, but migrated my interests towards stupid things like race cars and such. My entertainment system has been turned into home theatre, but in the future I'd like to move towards maybe a dedicated music setup. I want to get my music in order, and this seems like a logical way to go. Am I missing something?
Administrator - "Tyson"
I ripped all of my CD's to WAV files on my server which is then played through my stereo via my PS3.
Very simple using a free app called PS3 Media Server - not sure if there is a MAC version.
Former Vendor
I have almost 100 gig of MP3's that I have collected over almost 15 years - 70,000+ songs. I keep it backed up in a RAID protected server. I also have a second off site server I sync the two drives together at every quarter or so. Hard drives are mechanical and WILL fail at some point.
The Penguin King
Ok, I went the Apple route. I've ripped all of my CD's to an NAS on my home network, and then uploaded them to iCloud using the iTunes Match service. Then I got an Apple TV, and installed it in my home theater setup. The Apple TV streams the music from the cloud, and I don't have to worry about having any of the computers in the house up and running. Sound quality is very good, and what is particularly cool is that using the Apple Remote app on my iphone, I can navigate through my music library and select what I want to hear without being in front of the TV to view the output from the Apple TV.
As a side benefit, I've found the Apple TV to be very good at streaming video from the net. We have a subscription to Netflix instant, and we've watched several shows now using it through the device. Previously, I've streamed Netflix through a BluRay player, and through a Roku box. Both had issues with network performance, often having to stop and adjust video resolution. The Apple device is working flawlessly, providing a good quality HD picture.
Now on to getting music to the patio...
Here is a question for the experts out there: How can someone save CDs in their original or better format on a mass storage unit, I would think a large solid state or convention portable hard drive for access and play back through the USB port on the new Panameras and cayennes. iPod functionality with titles, artists, selectivity, on the touch screen but with WAV quality sound?
SONUS with RDIO - Second to none.. and you get to save music images to iphones as well..
Audio in most cases is above avg in compression in some cases 384K bit rate..
check it out.. I have it in both homes..love it
Matt, thanks for your reply. I think I should explain a bit better what I think I am looking for. I want a portable hard drive that will be powered by the USB interface in the Panamera and Cayenne, that will act just like an iPod but play WAV format music. I would want to be able to access the files and folders through the touch screen on the PCM and see the names of the artists, titles of songs and playlist names. The portable hard drive will sit in the console just like the iPod is designed to do. Essentially I want complete iPod-like functionality but be able to play uncompressed CD format music through the audio system. Oh and as long as I am asking for the world would want to store 5000 titles in WAV form. Thanks so much for your thoughts. It appears that the item you suggested is more for the home situation. I am looking for a mobile one. Doug
Ah Sorry Doug.. miss understood !
What I did was added a USB hub for my 911 with the USB option..
This allowed me to put on my iphone 64BG of music and 32GB USB and ability to select simultaneously without having to switch..
I would worry what MAX size usb drive you can add .. Uncompressed music will take up lots of space.. I recommend 256K or max 384K bit rate.. Id be shocked if you could hear the difference compared to 1140K uncompressed wav file.. keep us posted.. Im rather interested in what you come up with
BTW.. I posted a pic of my USB HUB.. the audio system in my 997.2 picks both systems up... wish the cable was a tad Longer.. maybe an extension cable would work ?!
