Bluetooth in ONLY-- does it exist?
Please excuse my rather naive question. I stopped paying attention to car audio sometime in the 2000s. I have a 1990 964 3.8 build with RS cams that is very loud. My future plans include headers and Gt3 center-exist exhaust, so it will get louder. The previous owner installed a mid-2000 alpine stereo, sub-woofers, tweeters, etc. that are just extra weight to me. Even with the volume up, the quality is lost over the noise from the engine. I don't want to replace with a heavy, multi-speaker system. In my other cars, I use the radio sometimes, and mostly just play music or podcasts over bluetooth.
So, in the interest of light weight and simplicity, I have a notion of replacing everything with just a bluetooth input. No headunit. Instead, I'll run a blanking plate. I may even run just a single speaker in the middle of the car to minimize the amount of wire I'd have to run.
Does such a system exist? If so, where could I find it? What should I be searching for? My lack of knowledge in car audio means my googling has been pretty clumsy.
Lastly, if possible, I'd like to run a bluetooth mic to make calls from the car, with a mic that run up the A-pillar and set up close to my face. Is that possible? I know I'd only be able to make calls while cruising at low rpm or parked, but I'm ok with that.
With appreciation for the wisdom of the collective.
Cheers,
B
Cheers,
B
Platinum Sponsor
Cheers,
B
Cheers,
B
My recommendation would be a bluetooth module like the one I linked above attached to a compact power amplifier to drive a "good quality" set of component speakers. The weight from a sound system like that is negligible and you'll get a good experience when you do listen to tunes. If you need some help navigation that whole process feel free to reach out – happy to help!
– Nick
