997.2 + slicks, oil starvation?
This integrated dry sump with 4 or 5 pumps --> can it handle semi slicks (Hoosiers) or real slicks without starving the engine of oil?
It doesn't look like that many people track the 997.2's much outside the GT cars. I have a 997.2 Turbo S that I track. I haven't tried semi/full slicks yet.
I searched but haven't found an answer.
I run r compound NT01 and track my GTS couple times a month in-season.
The manual specifically says not to use slicks and the dealer said I'd void the warranty on slicks (still on CPO). R compound they gave me a high five and said have at it.
I have read some stories (2 maybe) of oil starvation on slicks but I see many many dfi caymans running slicks at the track. I've asked them and, anecdotally, they just blink and laugh... no problems.
big question is, are you racing or just DE? Do you really need to shave 2-3 sec a lap and risk oil starvation in DE? only you can answer that question. either way, glad to hear a turbo is being tracked!
I just installed an LN Engineering deep oil sump. I'm also curious whether this would help.
The stock pan's smaller volume looks better baffled (higher walls) to me to prevent oil slosh in cornering but the deeper finned pan probably allows a lower oil temp when the cooling fins get air flow through them when driving (as more surface area exposed to the ambient air for heat transfer).
What I'm worried about that at my home track there are two turns where the inside wheel is on the curb/bumble strip, the "sausage" is between my inner and outer wheel, and my outside wheel is on the asphalt. I'm wondering if this is going to clear that sausage.
Trucker
You raise the bar big time when you go to slicks: lots more stress and strain on axles, wheels ends, studs/lugs, brakes, everything goes up. Do you really need slicks on an AWD car? IMHO
MPSC2s are great except in wet.
I don't have a 997TT so I should take my ball and go home. GL.
With that said: I've avoided taking hit of the Hoosier crack pipe so far. They don't last long before grip starts to fall off (Ive been told 1.5-2 days and then grip tapers off) and they are pricey. I've stuck with Nitto NT01s which seem to have more grip than MPSC2 from what others says but are half the price and last 3x as long. I'm on 6 DEs on my NT01s at advanced group pace and still have about half the life of the tire remaining.
If you want to go with slicks, perhaps look at buying scrub slicks from race teams to start out with to test how your car does with the extra grip and save yourself a couple thousand bucks to experiment with. There are some threads if you search in the 997 GT3 forum where guys buy slicks that teams used for a couple sessions and still have plenty of life in them for super cheap that still have some good grip left.
Is it true Hoosiers are around 2-3 seconds faster than a Cup2 on a 2min lap and slicks another 2-3 seconds?
The DFI engine in the .2 cars has much more efficient scavenge of oil from the cylinder heads, which was the downfall of the m97 engines which had all the starvation/heating issues. I ran my '09 cayman s (dfi) on hoosiers for couple of track days and time trials on hoosiers, pretty hard, with no issues. Still best to keep oil fresh for each weekend, as the total volume is less than the mezger dry sumps.
