Cab Top Service?
I have a turbo cab as well. I just cleaned out the drains and it is quite simple to do. Raise the roof to the top service position which exposes the drains on either side of the car (roughly in line with the turbo inlets). I simply took a small vacuum hose I had laying around and fed it through the opening and hooked up my shop air to the tube and blew it out slowly with a low psi on the regulator. Took 5 mins.
Thx. Yep.......the drains are an easy clean.
Check the front drains too.......located either side of the battery. Again, easy - vacuum the big stuff, blow the small stuff through.
