Recommendations on tire sizes for Champion RS171's?
Hi all,
I recently acquired a set of Champion RS171's in Turbo fitment: 19 x 8.5 and 19 x 11.5.
Wondering what the recommendation is for tire sizes? I haven't seen a definitive answer and a lot of discussson recently.
Thanks, TT Surgeon!
I also reached out to Tom @ Champion, who got back to me with recommended stock sizes. Specifically, he said:
"235/35/19 in the front, and 305/30/19 in the rear"
He also confirmed stock lug nuts + wheel caps work. So, it essentially sounds like you can go with whatever options you use for stock wheels (including upsizing the width).
I have the same rims and have been running 245/35/19 & 325/30/19 RE11's without any issues. Have run the sizes you mentioned above as well, that is until the 245's and 325 RE11's became available. So yes, essentially you can run either option. : ]
If you go with MPS CUP's stick with 235/305's, as they are fat tires!!!! You can also safely run 7mm spacers all the way around on lowering springs with all of the tires/sizes mentioned above. You will need longer lugs though.
Cheers,
VID
Cheers,
VID
