Pinning cooling pipes labor time
So anything definitive on labor hours?
Cindyscott thought perhaps 10 hours. Presumably that's if you take it to a shop for JUST that one service?
Can anyone confirm?
ALSO,... what would you think the hours should be if the pinning job is done while the engine is already out?
Many of us are doing it as preventative maintenance while doing a clutch etc.
Can anyone confirm?
Yes. I have actual numbers for Porsche Dealer. Not independent.
The cost of doing this is about 5,800 30-32 hours of labor + 3k in parts. Which is quoted from 3 different local dealerships. I called Porsche Walnut Creek, Livermore and Fremont and got these estimates.
You will also need to do a water pump, and some various other seals/gaskets.
If you have them remove the plumbing consoles and send to sharkwerks for service can save money in parts. But you will owe sharkwerks about 400-500 in labor.
There's also the sharkwerks water fittings, should you choose those. 535. for a set to replace the plastic ones.
Expect about 9k when all done.
BTW- While in there, do spark plugs, fuel filter, coolant, oil, flush pentosin system, cam sensor, etc... it add's up quick.
20POZ ENGINE COOLING SYS
6961 CP 5800.00 5800.00
1 997-106-002-70 WATER-PUMP HOUS. W.O 1719.83 1450.86 1450.86
2 999-707-410-40 O-RING 4.83 3.86 7.72
2 996-106-214-70 PROTECTIVE RING 7.54 6.50 13.00
4 999-707-411-40 O-RING 7.25 5.80 23.20
1 999-707-468-40 O-RING 7.25 5.80 5.80
1 999-707-315-41 O-RING 2.40 1.92 1.92
1 997-106-340-00 GASKET, WATER PUMP, 13.74 10.99 10.99
2 999-701-789-40 RUBBER O-RING 0.97 0.78 1.56
4 999-701-789-40 RUBBER O-RING 0.97 0.78 3.12
2 999-707-316-41 O-RING 2.40 1.92 3.84
1 999-707-364-41 SEALING RING 2.40 1.92 1.92
1 900-123-010-20 PUMP SEAL, COPPER 0.97 0.78 0.78
1 999-707-481-40 RUBBER O-RING 4.83 3.86 3.86
1 999-707-422-41 O-RING 7.25 5.80 5.80
1 999-707-426-41 O-RING 7.25 5.80 5.80
1 996-107-217-71 SEALING, OIL-FILTER 7.70 6.16 6.16
1 997-110-319-00 RUBBER SEALING, DIST 10.99 8.79 8.79
3 997-110-747-70 SEALING, INTAKE SYST 27.55 27.55 82.65
1 997-106-039-72 AS WATER NECK 302.45 257.08 257.08
1 997-606-420-00 TEMP SENSOR WATER 29.39 24.98 24.98
2 996-106-214-70 PROTECTIVE RING 7.54 6.41 12.82
2 900-123-152-30 SEALING RING 1.36 1.09 2.18
2 997-111-217-70 STEEL GASKET. 20.14 17.12 34.24
1 996-106-529-73 COOLANT HOSE 13.01 10.41 10.41
1 900-123-010-20 PUMP SEAL, COPPER 1.04 1.04 1.04
1 900-123-118-30 ALUM SEAL RING 1.04 1.04 1.04
1 999-703-349-00 BONDED RUBBER MOUNT 12.30 12.30 12.30
1 999-707-355-40 O-RING PWR STEER DRI 5.03 5.03 5.03
1 996-106-326-71 SEALING 9.00 9.00 9.00
2 999-707-472-40 O-RING 5.03 5.03 10.06
1 997-106-233-72 WATER HOSE 28.90 28.90 28.90
1 999-707-298-40 O-RING 8.06 8.06 8.06
1 999-707-465-40 O-RING 10.38 10.38 10.38
9 WTY-000-003-A ENGINE OIL.SYNTHETIC 7.00 7.00 63.00
4 999-073-505-01 TAPPING SCREW 4.8X16 1.19 1.19 4.76
2 999-591-629-01 CAPTIVE NUT 2.23 2.23 4.46
30 REMOVED ENGINE AND TRANSMISSION ASSEMBLY, R/R OIL TANK, INTAKE
MANIFOLD, EXHAUST, OIL COOLER HOUSING ASSEMBLY AND REPLACE PLASTIC
COOLANT ANGLE FITTINGS WITH CLIENT SUPPLIED STAINLESS STEEL ELBOWS FROM
SHARKWERKS, PER CLIENT REQUEST SENT COOLANT HOUSINGS TO SHARKWERKS FOR
PINNING OF FITTINGS, REPLACED FRONT ENGINE COOLANT CONSOLE AND LEFT
SIDE COOLANT SIDE PIPING, REMOVED RIGHT SIDE COOLANT HOUSING UNDER
POWER STEERING PUMP AND SEND OUT ALL COOLANT HOUSING FOR FITTING
"PINNING" AT SHARKWERKS. REPLACED COOLANT TEMPERATURE SWITCH. WITH
ENGINE REMOVED, REPLACED ENGINE CRANKSHAFT POSITION SENSOR, WATER PUMP,
FUEL FILTER AND SPARK PLUGS WITH CLIENT SUPPLIED PARTS. CHANGED OIL AND
FILTER.
FILTER.
Can anyone confirm?
Can anyone confirm?
It's probably 8-10 hours to pin once the engine's out, in other words.
Had a minor leak on an 08tt at one of the coolant fittings at 30 thousand miles. Pinned lines and added sharkwerks oil coolant fittings. Removed leaking fitting and used loctite 263 to reinstall ( recommended by sharkwerks) then pinned the fitting. Porsche dealer would only re epoxy. Some people have welded the coolant fittings, I didn't want to take mine apart to clean for welding if they weren't leaking. Good write on sharkwerks website if you want additional info. Shark werks has repaired a lot of these.
Crazy amounts of labor time. I guess I lucked out with mine. None were leaking, and none were loose...they charged me $500 while the motor was out to drill, tap, and pin the 7 fittings. I also had the sharkwerks metal pipes installed while it was out as well, so maybe already having the intake manifold off helped lower the time needed for the pinning of the pipes further.
Can anyone confirm?
Can anyone confirm?
I had a local shop do the work on my 08tt. It cost $3500. Took three hours to remove the engine. We replaced the water pump, hoses, gaskets/orings ( pump remova), pinned coolant lines, replaced ignition coils and plugs. Parts were approximately $1500. The water pump and coils were close to a grand alone. The rest was labor. Tried to take advantage of having the engine out to get any possible maintenance done. Porsche shop wouldn't pin the coolant lines. They would only re-glue them to original. Plus labor and oats cost were much higher. I did this because I had a minor leak in one of the fittings.
I had mine done after one of the 90deg coolant elbows below the plenum let go partially. ordered the sharkwerks 90deg kit and then had the engine out and pinned all of the coolant pipes etc and installed the sharkwerks kit. mine is an 09' with only 52,000kms on it. labour and parts was $5800 plus the $400 for the sharkwerks elbows. its not a bad job with the engine out. quite easy and quick to do. The elbows was the time consuming part as the plenum etc had to come off and we decided to reseal all of the oil gaskets etc.. so no future problems.
Wish I had read this thread sooner ! Driving back home at 11 p.m. I decided to floor the gas pedal (Tip Transmission) so much so that I got an engine cut off ! Three minutes later I get a check coolant level, after which the temperature gauge starts blinking. Pulled over and saw water vapor coming out of the rear vents. Drove straight to the dealership, left a note on the dash to my service advisor and called a cab home. Wish I had taken the precautionary measures before this happened ...
That sucks guys. I had mine done while my engine was out for tranny warranty work, nuthin leaking, one of those 'while you're in there' things, not convinced it actually needed doing. Unless you're actively leaking, I would only do it if you're pulling the motor for something else.
