Build Sheet Option Code 220
On my 2013 911 Turbo build sheet option code 220 shows as "Limit Slip Rear Different Lock". I have noticed on other Porsche models code 220 shows as "Porsche Torque Vectoring (PTV)". Does the code 220 on a Turbo include the diff lock and torque vectoring?
PTV is just an updated name for LSD.
^ Neither are quite correct...
"Porsche Torque Vectoring (standard on 911 Turbo S models, optional for 911 Turbo models), with variable torque distribution to the rear wheels and a mechanical limited-slip rear differential, is a system that actively enhances vehicle dynamics and stability."
On the non-Turbo cars, 220 means the car is equipped with just the LSD option. I believe PTV is not available for non-Turbo cars.
On Turbo cars, it's the PTV (which like you mentioned includes the LSD).
