Dyno results are in...
Finally got the car on a dyno today and confirmed my suspicions, the car runs as good, if not better on pump gas than it does race gas. The race gas file is green, pump file red. It's a giac tune. I data logged a bunch of numbers but haven't had a chance to go through them yet. Will post durametric files when I get a chance.
I'm not familiar with dynos but, I thought I would see more with your setup.
By no means am I trying to discredit anything but, you ran some really decent times over a year ago.
Timing may have to do with your drop off for file comparison.
I agree 100% which is why I wanted to get some numbers on the dyno. I was running right around 11.1-11.2 with the pump profile and about the exact same with the race gas profile. This session confirmed my suspicion that I wasn't really making any more power on race gas. From about 5700 rpm's and up, I'm making more power and torque on the pump gas profile. I'm hoping the durametric numbers will help answer why.
I ran the first 3 runs on the race gas profile and then switched the tune to the pump profile with the same fuel, 100 unleaded. The main difference between the two profiles is the timing is advanced on the race gas profile.
...thus I'd bet your pump gas tune numbers were a good bit healthier with 100+ octane in the tank then they would actually be with just 93 in the tank.
If my reading comprehension isn't completely in the toilet if green is race gas and red is pump gas the green HP number is higher than the red HP number.
Looks like race gas vs. pump gas while both HP and torque start up at higher RPM they go up quicker and remain higher and flatter with the race gas.
The drop off at higher RPMs could be the race gas might be a bit stale. A fuel test in EVO some years ago found race gas in a stock turbo-charged car was ok at lower RPMs but really came alive at higher RPMs and just blew the pump fuels into the weeds.
Data might shed some light on the drop off too.
