CD Changer removal?
CD Changer removal?
Since I have an aftermarket head unit in the car I don't need the changer and would love the extra room. However i've been doing research and it looks like it's near impossible to remove and that the bracket holding it in place would require messing with the amp and possibly exposing it. Wondering if anyone here has done this.
Only info I found was here which wasn't encouraging.
http://www.6speedonline.com/forums/9...r-removal.html
I'd be keen to know as well. No need for CDC or Nav, would like to remove.
If I get more time I will try to provide more....But basically you pull straight up with a trim tool hook on the outer case on the nav and/or cd changer....it is hard, but will snap off with enough pull. There are two nuts holding the changer in place. One more difficult to get to. Nav cover needs to come off first....and will need a MOST loop after removing. Connectors are on the bottom...2 plugs.
Hope that helps...
DC
Hope that helps...
DC
Easy job - took me about 20 minutes.
Just remove all of the trim in the frunk. Bracket is easy to remove once you have done that. Make sure you have a MOST loop cable to add on to the most line when you disconnect it from the CD player.
can you advise on this most loop thing? i don't have navigation anymore because I have a pioneer NEX unit. Not sure what you mean by needing this loop and what to do with it. thanks
So if you had/have OEM PCM unit, the fiber optic/MOST plumbing passes light in to one side of each device in the loop, then out of the other side to the next device. If you just unplug a device, you break the loop.
Example...Orange fiber optic cable sends light flashes/signals out one side of the head/stereo unit....it may next pass to the IN side of the AMP...then out of the OUT side of the amp, then on the IN side of the NAV system, then out of the OUT side of the NAV, then on to the IN side of CD Changer....etc....Back to the IN side of the head/stereo unit.....If you break the loop anywhere, the signal never comes back and you will get errors as it cannot complete the loop.
Now after all that...If you switched out your system and are not using the CD Changer...not an issue.
Here is an example of the loop, and the CD changer and how to pop the cover with what...
Hope that helps some.
DC
MOST Topography:
CD Changer, Loop and tool to pop off:
Loop:
If the NEX unit is hooked up via a NAVTV gateway you'll still need the optical loop.
thanks for the info. No clue how the NEX is hooked up. I did previously have NAV TV, but not anymore. Seems like this could be a pain. Also have to double check but thought my changer was hooked up to the front of where the amp is, not on the side.
Do you know if you're still using the OEM amp? If so then you will be using the fibre optic ring.
Isn't too much hassle. Just a case of ordering a fibre loop cable or two and if the stereo stops working after you've disconnected you can install the cable. You could try it now relatively easily - take of the cd changer cover and disconnect the fibre optic cable. Is a black connecter with orange cables. See if it stops working.
No idea. Space is more valuable than weight though - can fit more luggage in without them in place.
Took all the useless crap out just bypass the fiber
