Check oil level alert
Hello, recently changed oil using liquid molly 5-40, in couple of ocations de check oil alert comes up; i stop check oil shows its full and alert light goes off! Could it be a sensor? The oil?? Its a 2011 turbo...
If it's showing full bars there's a chance it has been slightly. I'd take out 2-400ml and see if the alert comes back. Run it at one bar less than full, if it alerts again it's most likely a sensor issue?
Car did it again yesterday after a couple of really hard pulls... Could it be the viscosity or that I didn't run mobil ?.. Ill try taking a couple of ml out as an option.. They did scan for errors and 0 errors founded
