New Member 997.2 Turbo S Modded Up
Ah yes of course. He was only running something like 10psi from what I remember. Needs more boost!!!!
At the Shift Sector 1/2 mile events they began using a remotely controlled tree at the start line similar to a drag strip so people could go from a standing start. While I didn't reduce tire pressure, I might try that next time as my launches were pretty bad. At the drag strip I dropped the rears down to 28-30psi and worked much better than stock at 40-44psi, but then I may give up 1 mph on the top end by doing this.
Would be good to invest in one of those air pump machines that get power from your car's cig lighter output that way you can lower/raise pressure when needed. I have one it was like $60 and all my buddies use it at these race events works great. If you need more info on it let me know.
1/2 mile is a long distance and the higher the tire pressure, typically the higher the trap speed. So I keep tire pressure stock for these events because they typically start from a roll-on of between 40-50mph and I get full traction (no spin at all) with r888 tires.
I do have a Craftsman 12V pump station with digital gauge, etc. built in, so I will take that with me to the event. My wife said she will follow me in the Cayenne and bring my big portable (15 Gall) fuel pump with race fuel...and I will add this air pump and some tools, and maybe a floor jack??
Thanks!!
DC
That is great....Kind of what I thought, but wanted your thoughts as you have done a ton of these, and I have done none
Thanks!!
DC
Thanks!!
DC
Perfect! The only other item I would recommend is a water sprayer. Put some water/ice to spray down your intercoolers. They get so hot between runs with your car just sitting because they are next to the engine which radiates a lot of heat. Spray them with cold water just before you do a run. Imagine the difference in IATs if your intercoolers right before your run are 180 deg vs 80 deg and wet!
I also have the Torque app for my Android phone/tablet and Bluetooth OBDII dongle, so I can easily watch the IAT etc...
Thanks for the tip(s)
DC
Thx saabin. Speaking of vids, here is a vid of the last Airstrip event I attended in May at NoFlyZone California. Enjoy:
https://www.youtube.com/watch?v=Vi4Wf-f_gUk
Perhaps I'm just a moron, but what are the rules on this race? You start from a stop, roll till you hit the cone line... then nail it? It seems almost impossible to get a fair start?
I know, I know, crawl back into my cave
Sometimes I do. The surface is really bad tho, not nearly as good as the street because there is a lot of sand and other debris on the starting line. Just depends on who is the opponent. If it's a GTR, then hell yeah gotta show them that they can't out launch a Porsche
From a dig it's pretty simple. Either go with the arm drop of if there is a tree (Shift Sector events), then go when the light turns green.
From a roll yes there is some coordination that needs to occur to be at the starting cone at the same time and at the same speed. Most of the time it works out, but sometimes it doesn't. A couple times in that vid people jumped me, and once on accident I jumped (on the R8). It happens and is just part of the game. Can always have a rematch.
Longboarder.
I love your cars! White M3's are my favorite! Your turbo is awesome.
Freakin love your videos. Very very cool. Great to have you on the forum. How many miles are on your turbo? Also do you track with the ceramics?
Phillip
Phillip
My Porsche just crossed 36,000 miles. She's a work horse for sure! I have tracked the car twice. Each time I track the car it goes back to BBI for a full evaluation of the brakes and suspension components. If there is any wear noted on the rotors, then that's the last track event ever. But there is little risk since I have decided to track with the stock pads. A more aggressive pad could wear the rotors.
I'm ok with that because I can track my M3 as well. But even at 600 horsepower with an aftermarket big brake kit, camber plates and race wheels/tires, the M3 is nowhere near as fast as the Porsche!
Beautiful car! Have fun with it. I know your's is modded, but I came across this (below) on ************. Seems you got a good car to start from! For me, bone stock, even for a few hundred feet on the street, DFI and PDK, boom, like a missile! Porsche never ceases to amaze.
Wow. Quite simply, wow. Talk about a car that just right out of the box impresses. Close to mid 10's and 130 in a stock car, incredible. The 997.2 Turbo S simply is a epic achievement. The launch control and PDK transmission clearly help as a 1.58 60 foot is mind boggling for a stock car on street rubber. The launch control system works and works very damn well. The result using it is a 10.672@129.80 for what is a new stock 997 Turbo 1/4 mile record
