Always takes two tries to start???
08 TT Cab. 21K miles
Usually won’t start on the first try. Then second try does it.
I found several discussions about it but no clear solution. Some tried new battery with mixed success so I think its something else.
If I leave the key in for 10 seconds then it will start on the first try. Any suggestions.
Received 5,388 Likes
All maintenance up to date? Including plugs?
Ever run a tank of fuel with Techron prior to oil change?
Trucker
A few years ago I was told that you also need to replace the battery in your "smart" ignition key. There is a security "hand shake" that takes place when you initially insert the key.
Has this ever been done?
Plugs were done at 20K, I'm at 22K miles. Original owner had a service record at 15K for the same issue. There was no problem found???
Battery in the key is a good suggestion, I'll try it. i find it odd that this is a common issue but without a definite solution.
Not a big problem after all, but people wonder why it doesnt start initially.
this happens to me too...
just took it to dealer.....they tested starter, battery, charging system, etc....(thank you CPO!)
all they came up with was that water in battery was low and it just needs to be serviced....
and i thought sealed batteries don't need to be serviced or topped off with water?....
I had this issue too and was considering changing to a new factory battery. Then a car buddy recommended reconditioning my existing battery with a CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger. I use their accessory cigarette charger plug and issue went away after plugging it in for 24 hours. It cranks up on first try every time.
Try this,...
Switch the key all the way on,.. but don't actually crank. Turn it back off. Then try to start it.
If it starts normally after doing that,... it's probably the check-valve in the fuel pump.
I had it happen to my last car. The check valve in the pump goes bad,.. and instead of holding 30 or so psi of residual pressure for weeks after the car is switched off,... it goes down to zero right away. They you have a LONG crank to start it each time.
I have the exact same problem on my 07 TT. I changed my battery last month to the OEM Porsche, and the problem still persists. So that rules out the battery on my process of elimination. I was told by my mechanic that Corrosion on the - terminals could also be the culprit, as well as potential issues with the cable harness from the battery to the starter being low gauge for the amount of amps needed. This latter theory I seriously doubt, otherwise the problem would have been prevalent when the car was new. The fuel pressure with the check valve sounds more like it.
What about coil packs??
This may be a reach, but in the early Porsches the ground points were very crucial and often problematic. If you're in a wet area or "salt state" it may be a good idea to inspect and clean the grounds.
