Clutch switch bypass
I want to disable the microswitch that won't allow the car to start without the clutch pushed in. From my friendly search tool, it appears that you can either make a small wire and connect the two towers or use a tie wrap to keep the plunger closed.
1) is there a preferred method?
2) if you do the wire bypass, is it just a matter of removing the two connections and making a jumper that connects them?
Thanks for any thoughts,
Here's one thread I found:
https://rennlist.com/forums/997-foru...placement.html
