Suspension upgrades
#31
Yes you can align it to gt3 specs, but I wouldn't make any determinations based on limited street jaunts in snow tires. With all due respect to tom at tpc, his job is to sell parts. I'm sure the dsc is great, but I'm not sure you're ready for it given your skill set. Again, align it to gt3 specs snd leave it alone. The dsc is really helpful with a 997.1 rather than a .2, bc the 997.2 suspension is better out of the box than a .1.
.2tt is an incredibly fast and capable car out of the box, incredibly user friendly, so mindful of OP's reported difficulties with the car it again reinforces the argument of driver training. Frankly without it he is endangering himself and others...
Cincyscott: DSC user feedback appears generally positive, and even the minor light issue is not a deal breaker for you. I think it needs to be accepted that 99% of these kinds of performance mods come with some small issue or other. Main thing is any minuses that are found by each user don't out-weight the pluses.
#32
100% true! The changes made to .2 suspension made a significant improvement to general ride and handling over .1. So yes I also probably wouldn't bother with DSC on this occasion.
#33
OP
My suggestion even before you take your car out to the track get it aligned or make any modifications is to sit with a seasoned driver in a 911.
I have more seat time as a passenger around a track then I do in my own car it is the most rewarding and valuable experience you can gain before going out in your own.
#34
OP
I'm OCD with my cars. I know how I want them to feel. I improve the car till it is to my satisfaction, and it's as simple as that.
But regardless, because I drove the newer 911 and 981 before I drove this one, I want to make it handle like the new ones if possible. So I'm still going to do an alignment and the DSC. I'll find someone local who has a .2 to test drive before I get the DSC to try it out on my car, since some thinks it doesn't have value on a .2. I'll be the judge of that for myself.
I do overkill, always have on my cars when it comes to suspension. It's not like I'm going crazy with it. We are talking an alignment and a module that takes 2 minutes to put in lol. I'm not creating a cup car here. I like predictable and safe for my goal. And any car can always improve in that regard.
But I can report out on the mods to see how they effect the car in every day driving. I like to do my suspension stuff one at at time to see the difference each part makes.
#35
Still plays with cars.
Jem - I wasn't ware that you had an alignment and are driving on winter tires. Winter tires are made of softer rubber designed to stay grippy even at -40 deg! As a result winter tires are a bit squirmy when driven on pavement. Handling is definitely less precise. Waiting for summer tires is a good idea. If this is a street car (no track or little track) I would not align to GT3 specs since with the negative camber you'll wear the inside edge of your tires prematurely. I would NOT use toe out unless you like a darty car that needs constant steering corrections to travel in a straight line. Even my race car has a touch of toe-in.
Regards,
Regards,
#36
Regards,
Regards,
#37
Placing fault at not having a dsc unit, stiffer shocks, or some other susp mod is not going to resolve your core issue with the car until you learn how to drive the rear engine chassis properly. The .2 car is a brilliant out of the box package and is very competent in skilled hands without need of any mods. In unskilled hands a car of this HP output would be like handing a baby a loaded hand gun so my comments were justified given your own comments.
As a friendly suggestion, once you have learned how to competently drive a 911 chassis then by all means fire away here and ask the questions about spending money on suspension mods. I thought Chris's earlier advice not to spend a cent at this stage was appropriate, yet that has evidently fallen upon deaf ears in a bid to blame areas other than your skill.
#38
Good god hand the man a chill pill! Jab not required, just reading your own words and forming an obvious conclusion as others have also done here, that you are well out of your depth with the car itself. If you want to take that as a jab then stay in denial.
It's all relative. My comments are not saying the car is sloppy in general as a car. I don't now how much clearer I can make myself. You need to learn to listen or at least read properly.
Again I am using the 991 4s as my benchmark. I am saying these things compared to the 991 4s. I was never worried about losing control on a 4s.
Also by Chris are you saying TTsurgeon? Pretty sure he said alignment and tires. Which is what I will do in 2 months. It's too cold right now.
We don't need another 10 page thread of your comments. I'll revisit the suspension after I'm back on summer tires. As I said before and I will say it one more time for the last time. I got this car in the dead of winter, I spent 2 weeks in below 30 degree weather on summer tires. I then switched to winter. So I do not have much experience on summer tires on this car. Therefor my opinion may change come spring.
Now I'd like to change the direction of this thread to alignments. Is this ok with you? Am I allowed to do this? Or do we need to argue for 10 pages?
So can people please post some feedback on the GT3 spec alignment. From a quick google search this seems to be popular. Is this different from the negative 1.5-2 camber and slight toe out? I'm wondering how come no one changed their spec now to a GT2 alignment.
What are the negative side effects of doing this?
#39
Moderator and 993 whisperer
From: At the track. I reside, however, in Navarre, FL.
Jem ... please take a step back. These people are trying to help you. That some are even still trying given some of your responses amazes me. When I first started out, I thought I knew everything. When I started truly listening is when my happy meter went up when driving. Nobody here is trying to put you down. We just really wanna see you get the full Monty experience. I bet if you look back on this thread a year from now, you will say something like, "Oh, man. That doesn't even sound like me any more." Meanwhile, soak up all of the data from the experience of those of us who have been right where you are now. I promise you are gonna love the journey!
#40
As far as toe, I would not go more than 1/16th IN. Too much out will make the car rather unpredictable mid-turn. If anything, just go for zero toe if possible. Probably the only car I can see wanting toe out might be an F1 car or something small and riding on the ground. I am sure the other folks will chime in if they feel my advice is incorrect, which I openly welcome. I am always up to the education.
#41
2) 10 pages is what you created as a consequence of your directing your last thread against the flow of advice which you sought out in the first instance. So it is every one else's fault that they found holes in your argument/responses?....and responded accordingly in a bid to put you straight?
3) GT3 Specs have already been provided along with informative and detailed links etc. Surely there is enough there for you to digest? Or, do we all need to add another 10 pages reinventing the wheel for you on that same topic?
PS. I don't suppose you have a picture of this car of yours? Normally photos are required.
#42
I'm even wondering how do sway bars effect this car, or going with lower control arms. But it seems there is more to this alignment than what was simply stated before.
#43
1) a) You had me fooled. Why then question the need for sways DSC's etc? 1) b)You are just being confrontational now because some here (inc me) have called you out on the obvious. Maybe you should consider articulating your position differently next time.....not that I feel in this instance the outcome would have been any different given your own words and, the questions you then asked against the responses given. Odd really. Not sure what you are hoping to hear? Did you want us all to say the car is a handling disaster, and you are a brilliant driver?
For you. I was going to post a lot of the ones I took in the new exhaust thread I will create once I get mine. It's not reinventing the wheel to ask what people have done for their alignments and to give real world feedback on them.
No one found any holes. All they said were get proper tires, alignment, go to a driving class for the car.
check, check, check. I will do all of them. No problem.
And no, we went 10 pages because you keep touting about europipe so bad to the point people questioned why you had so much blind love for it, and the thread was about people's experience with kline. Not europipe. But let's not bring that up.
But that's ok. I don't want this thread to become a mess again, which clearly you will do your best to make sure everyone I start is. I got the answers I needed for now. Thank you all who gave constructive advice, I appreciate that.
/endthread
#45
Attachment 909977
/endthread
/endthread
I even told you on three separate occasions to buy the Kline inconel (not an EP) as did other posters there. You were the main one banging on and on and on about europipe and putting up god knows how many soundclips and other elaborate commentary on the system. I was wondering if were you on the payroll lol. Ridiculous! And still no sign of any system least of the all the inconel you were asked to buy.
Attachment 909981
Here is one of the interior while we are at it. Now speed, if you want to see more you are just going to have to be patient. I promise it will all come .
