Battery suggestions
Battery suggestions
So 7 years in and 27k miles this baby needs a new battery. Hoping it fixes the occasional 3k rev at startup too.
What do you guys recommend for a new battery?
Received 5,413 Likes
Walmart
Autozone
Interstate
Autozone
Interstate
Trucker
Get a dry cell battery instead of (leaky) lead acid, preferably an AGM (advance glass mat) made by Interstate or Optima.
Fully charge the battery on a charger prior to the installation.
Optima's are great...but they don't fit in the tray without modifications. I believe Interstate and Duralast have AGM in the H7 size.
I just got a Bosch AGM that fits perfectly
Miserable Old Bastard
Personally I think the main brands - Interstate, Duralast, whatever, are just fine. H7. Not worth stressing, just grab one and slam it in (takes 5 minutes).
Yep I believe that is it (however there is an AGM Bosch and several standard lead-acid so double-check) -- and yes Pep Boys! It's kinda funny thinking of going there for higher-end European car stuff, as your first thought is pine tree air fresheners and chromed F150 taillights, but I have had good results with them and it's quick in-and-out. They had the special 12-pt socket for my recent steering wheel swap too, which neither Sears nor my local hardware store had.
Btw only autozone had the battery I needed in stock.
I think this may have been the solution. I originally thought it was the tune and that bothered me since I was worried they did a shabby job. With the battery being 7 years old and low on juice I'm glad I changed the battery anyways, I have a 5 year warranty. I also read that if you allow your battery to go dead it can be a major problem because you won't be able to get in your trunk since it's battery powered. Not sure if that's the truth, but some guy on 6speed had to flatbed his. So worth while checking your battery if you're around the 5 year mark.
Hopefully no more overrevs!!! ...but i'll report back in a few days or so. This is a DD so I drive it often.
