GMG 997.1 WC Turbo with JRZ RS Pro Coilovers, GT2 Bumper, Cup Wing, Exhaust
Basic Sponsor
GMG Porsche 997 Turbo Exhaust
The GMG Porsche 997 Turbo exhaust system increases overall performance, enhances the sound, and reduces weight. Handcrafted out of T304 Stainless steel and meticulously TIG welded to aerospace specifications with great precision, the system is lighter than the factory system and displays a level of quality that is unsurpassed. Weighing 37 pounds, the GMG exhaust system is 20 percent lighter than the factory system.
The system features German made 200 cell sport catalysts that are OBD2 compliant with proper 02 sensor placement to ensure no CEL (Check Engine Light) and a crossover x-pipe to increase power by balancing exhaust gas pulse coming from the engine and adds to the signature sound that only the GMG system can offer.
The crossover x-pipe works by balancing the exhaust pulses from either side — or cylinder bank – of the engine. It allows the exhaust to flow down the path of least resistance while speeding up exhaust velocity. At lower revs, turbulence is formed as exhaust gases try to shuffle past a second column of gases coming from the other side. While always producing more power than the restrictive factory system, exhaust speed is increased as the engine revs increase. The X-Pipe merges the exhaust into two uniform streams, allowing a smooth flow from engine to exhaust exit.
Stainless steel packing is used our mufflers to withstand extreme exhaust temperatures and high intensity acoustic pressures that are generated by the turbo system that is located within very close proximity. This is one of the key advantages of the GMG exhaust system since most other exhaust systems uses fiberglass packing instead to lower costs, and they are prone to rapid deterioration. The exhaust system is a direct bolt on replacement for the factory system and includes all necessary hardware.
Key Features
- Horsepower and torque increased up to 30hp without software upgrade
- Deep aggressive exhaust notes at lowers revs & exotic high pitched exhaust notes at higher revs
- No unwanted cabin drone
- Constructed out of US Made T304 stainless steel
- Hand built in the USA
- Meticulously TIG welded throughout to aerospace specifications
- Each system is individually serialized with laser etched badge
- Signature Brushed Finish and Quad tip design
- Significant weight savings over the stock system
- OBD2 compliant German made 200 cell sport catalysts
- No CEL (Check Engine Light)
- Stainless steel muffler packing
- Direct bolt on replacement with all hardware and clamps included
GMG Porsche 997 Turbo Headers
The latest GMG Porsche 997.1 Turbo exhaust manifold system is handcrafted from the 304 stainless steel and features equal length tubing and large 3 into 1 merge collectors. The GMG system is designed to reduce exhaust back pressure and complements the 997 Turbo's capabilities with improved throttle response and an increase in power and torque output. Utilizing equal length tubing and large 3 into 1 merge collectors, smoother flow of exhaust gases is achieved.
To prevent premature cracking or warping, the GMG manifolds utilize laser cut flanges and turbo flanges are meticulously TIG welded. Proper welding technique is very critical for turbo headers due to the high stresses they see when in use. Thicker stainless tubing is used versus standard thin wall stainless to reduce heat and to direct more exhaust energy to the turbochargers. The GMG Porsche 997 Turbo exhaust manifold system is designed to work with the factory turbochargers as a bolt-on replacement.
Key Features:
- Large primary runner with a 3 into 1 collector
- Improve throttle response and reduce turbo lag
- Increase horsepower and torque output
- Smoother flow of exhaust gases into turbocharger
- Reduced temperature
- Laser cut flanges to ensure no warping
- Meticulously TIG welded for exceptional strength and durability
- Designed to work with factory turbochargers
JRZ Porsche 997 Turbo RS Pro Coilover Suspension Kit
The JRZ signature RS Pro line of performance dampers for Porsche 997 models that have been developed through our motorsport partnership with JRZ.
About the RS Pro Line
The RS Pro line offers the best high performance club sport damper available today. Combining the best aspects of our RS and 2-way racing damper, the RS Pro gives the owner ultimate suspension tuning ability while maintaining compliance for driving on public roads. A monotube double adjustable damper with adjustable gas pressure, the RS Pro offers an increased adjustment range allowing the user to tune the car to their needs further. The RS Pro is available as a complete kit with springs and mounting hardware.
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate. To customize track to track setups and tailor the chassis to the JRZ RS Pro has an extra large adjustment range. Each adjustment is designed to be an even step giving you predictability when making changes.
Features:
• 22mm rod strut, 16mm rod damper
• 12 clicks of compression, 24 clicks of rebound
• Adjustable gas pressure, monotube
• Piston designed for high performance
• Large adjustment range
• Fixed hoses for easy mounting, available quick disconnect fittings
• Remote reservoir or piggyback canister
Benefits
• Better chassis control for higher rate springs / power /aero
• Street ride, racing performance
• Easy to change configurations
About JRZ & Motorsports Partership with GMG Racing
JRZ a leader in racing damper technology with 50 years of experience in research and development of suspension and damper design for racing, rally and industrial applications. JRZ is the official partner and supplier to GMG’s 5 car Audi R8 LMS GT3 program that is running in the Pirelli World Challenge GT series.
GMG Porsche 997 Turbo Adjustable Sway Bar
The GMG Adjustable Sway Bar Kit for the Porsche 997 Turbo helps reduce body roll and offers a wide range of adjustments to fine tune the vehicle handling characteristics.
Featuring hollow tube bars that have 3 adjustment points in the front and in the rear, the GMG sway bars offers an increase in stiffness over the stock bars and a wide range of adjustability. The objective of a sway bar is to reduce body roll and stabilize a vehicle under lateral forces. Having the adjustability permits the roll stiffness to be tuned by increasing or reducing the length of the lever arms for different situations without replacing the entire bar. To improve the responsiveness of the vehicle, polyurethane bushings are utilized instead of rubber because the rubber flexes, compresses, and stretches when put under stress.
The GMG adjustable sway bar kit is designed and manufactured by Eibach exclusively for GMG. Through the motorsports partnership, GMG developed lowering spring kits for high performance street applications using the data and knowledge gained over the years from professional racing in the ALMS and Pirelli World Challenge Series. The result is the improvement in the handling without costing thousands of dollars like the bladed racing versions that are used on race cars.
Sold as a complete kit, the GMG sway bar kit is a true bolt on upgrade that requires no modifications to your vehicle and works with the OEM sway bar drop links and dampers or any aftermarket damper such as JRZ or Ohlins.
Key Features
- Improves Handling and Reduces Body-Roll
- Increased Stiffness Over OEM Bars
- 3 Front and Rear Adjustable Points to Fine Tune Handling Characteristics
- Urethane Bushings For Increased Responsiveness
- Precision Hi-Tensile Steel Alloy, Cold-Formed, Tempered and Shot-Peened for Long-Lasting Performance and Durability
- Forged Ends and OEM Style Pressed Bushing Locaters (No Welding Or Weak Points Here)
- Manufactured by Eibach to Proprietary GMG Specifications
GMG Front & Rear Bump Toe Steer Kit
The GMG bump & toe steer will give you the toe adjustment needed that is not available with stock links and minimize bump steer. This kit is highly recommended for vehicles that have been lowered with aftermarket lowering springs or a full coilover suspension kit.
In addition to adjusting toe, it will also allow you to correct bump steer. A car that bump-steers requires constant steering adjustment to maintain a steady trajectory over uneven surfaces. The result is an annoying steering wheel jerk whenever you go over any bumps in the road, and bump steer becomes more severe with lowered ride height.
The adjusting link has a left and right hand thread on each end. Rotating the link will increase or decrease the overall length of the arm. A precision Teflon lined spherical rod end replaces the compliant rubber factory bushing for improved suspension response and feedback, and also reduces toe changes during acceleration and deceleration. The result is improved stability and control.
GMG Porsche 997 RSR Adjustable Thrust Arms
The GMG RSR Thrust Arms are direct replacements for the factory arms, and it will precision caster adjustability and improve handling.
The adjusting link has a left and right hand thread on each end. Rotating the link will precisely increase or decrease the overall length of the arm.
Spacers included for setting stock or anti-squat and anti-dive configurations. A precision Teflon lined spherical rod end replaces the compliant factory rubber bushing for improved suspension response and feedback.
GMG Porsche 997 Thrust Arm Bushings
The GMG Thrust Arm Bushing Kit replaces the flexible factory rubber thrust arm bushings to significantly improve handling and responsiveness of the vehicle.
Stock rubber bushings compress under load, causing unwanted caster changes in both front and rear suspension under acceleration and deceleration.
This allows the alignment to wander and makes the car less predictable. Our solid aluminum design eliminates compression to hold alignment settings precisely with minimal effect on road noise transmissions into the cabin. Compatible with all stock lower control arms, as well as adjustable GT3 and Porsche Motorsport Cup arms, each kit is sold as a set of 4 for both the front and rear arms.
GMG Porsche 997 Rear Adjustable Upper Control Arms Kit
The GMG Dog Bone Kit are a direct replacement for the factory rear upper control arm links to allow adjustment of track width and kinematic toe. Each adjusting link has a left and right hand thread on each end. Rotating the link will increase or decrease the overall length of the arm. In addition to added adjustability, precision Teflon lined spherical rod ends replace the compliant factory rubber bushings for improved suspension response and feedback
GMG Porsche 997 Monoball Kit
The GMG Monoball A-Arm Kit replaces the rubber lower control arm bushings and will signifigently improve the handling and feedback from the vehicle. Sold as a kit of 4, this kit is a must for track cars and they are very compliant for street use with minimal road noise being transmitted to cabin
GMG Porsche RSR Roll Bar
The GMG RSR roll bar features a 2 piece design and 1.5” diameter 4130 chrome-moly tubing that has been meticulously TIG welded for superior strength and rigidity. The 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points) whereas the factory Tequipment bar mounts only to the front and rear seatbelt mounts. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut. This design does not only provide superior protection but it also stiffens the chassis, improving the responsiveness and handling of vehicle, and allows for ease of installation.
Key Features
- Made of 4130 chrome-moly
- Meticulously TIG welded and normalized at all joints
- Mounts to front seat belt mounts and rear strut towers
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with stock seats or any aftermarket seats on the market.
- Designed to work with clip in kit for harness (no need to drill holes in your floor to mount the harness anchors)
- Bar comes complete all hardware needed to install
- Finished in satin black powder coat. Other colors available
- Made to order with individually serialized laser etched plaques
GMG Rear Deck Lid
GMG Cup RSR Style Carbon Wing
International Shipping is Available and Wholesale Inquiries are Welcomed
Professional installation is available at our facilities in Orange County California or through our worldwide dealer network in Europe, North America, Latin America, Africa and Middle East, Asia and Pacific.
For all questions and inquiries, please email Jerry@GMGRacing.com or Sales@GMGRacing.com
-Jerry
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
