FS: Girodisc 350mm rear rotors 996TT/GT2/GT3/C4S/997TT/GT2/GT3
I have an extra set of Girodisc 350mm rear rotors for sale. These are the latest generation of the Girodisc rear rotors and consist of the anodized aluminum hats bolted via anti rattle hardware to 48 vane slotted rotors. The complete assembly weighs only 15.8lbs per rotor saving about 5lbs compared to the OEM one piece assemblies. The rotor ring can be economically replaced when it wears out while the rotor hat is reused. The rotors only have just over 3K miles on them. The rotor surface is perfectly smooth and measures out at 27.72mm. New rotor spec is 28mm with 26mm as minimum. These rotors will bolt on to any 996TT/C4S, 996GT2/3, and 997TT/GT2/GT3. If your car is a 996TT/C4S or the first generation 996GT3, and came stock with 330mm rear rotors, you can still use these with your stock calipers by simply using 12mm spacers and 85mm Porsche caliper bolts. I can provide a set of the caliper spacers and longer bolts for an additional $40. These rotors sell new for $1200 per pair. I am offering these at $695 for the pair. Shipping is $50 CONUS. Buyer is responsible for any paypal fees. If anyone needs a matching pair of 350mm Girodisc fronts to go with these, I have a brand new set of fronts (either TT or GT2/3 offset) that I can bundle in. Feel free to contact me with any questions.
[url=https://flic.kr/p/noxuew]![](http://www.6speedonline.com/forums/attachment.php?attachmentid=376443&dateline=1400539043)
[url=https://flic.kr/p/nF22f5]
SOLD
