Suspension issues - Need help with a diagnosis
And to top that off Igooz when doc sold the car he said it had the same stock clutch which he said never slipped even with the FVD tune after nearly 80,000 miles ( and 125 track days). Beat that! No wonder he never wanted to sell that car.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
All i can say is that doc ought to write into Porsche AG and put em straight that he managed all that and I reckon he could wind up as the new poster boy alongside Webber. Actually may even knock Webber off his perch...and Rohl will be put on notice as a butcher....for all the stuff he wore out whilst on the payroll.
Trucker
Let's get back to OP...
He is a cruel man. Must be all that surgery.....TT surgury that is.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Verdict: Warped both rear rotors.
Also, didn't looks close enough at the box so though was told the pads were all Pagid yellows, turns out the fronts were blacks and the rears were yellows.
I'm not sure weather I warped the rotors when I cooked the brake fluid with my OEM pads and just noticed it the next day when I put the new pads on or weather I warped the rotors with the new pads because I hadn't completely flushed the system and or only put it Fuchs Maintain Dot 4 to replace it.
I guess it doesn't really matter. Damage done. Lessons learned.
Plan is to flush the brake fluid, add racing fluid, replace the rear rotors with OEM, and change the front pads from black to yellow (and try to sell the blacks). Does anyone see any problem with running the Pagid Yellows with the OEM rotors?
Also, is there anything I should know that's special in changing the rotors on our tts? I haven't looked at it closely (as it's in the shop) but am I safe to assume it's just a remove the calliper, remove the screws, remove the rotor, replace and reassemble? Are there Jack screws?
Wtf, do you memorialize every post I make?
Didn't realize I had a fanboy.
Castrol SRF brake fluid and pagid RS29 pads with stock discs will work nice.
Trouble with oem front rotors is the cooling holes tend to crack. Rears are fine.
If you can find alternative front rotors such as girodisc, protosport etc then you will have a great combo.
I don't know what you can't seem to process, all I said was that I only ever used stock pads, many sets, but always oem. I routinely changed pads each track day, and rotors once a yr, so whats your point? What pads do you use in your vast experience?
PS doc love the new avatar and the last one was pretty cool too.
Found some OEM rotors for the rear to replace the warped ones. One final thought before I replace them, is there anything I need to do with the emergency brake?
