When to change spark plugs
I had a Softronic tune done to my car in 2012 and I have never had an issue. She drives like a champ. No CEL's. At the time I had the tune done I also changed my spark plugs to the cooler Denso IKH-22's. I put about 4000 miles a year on my car. The last time I changed my plugs was at the 9500 mile mark. The car has approximately 17,000 miles on her at this time. When is a good time to change the plugs again? Would the 20,000 mile mark be the time? I only ask because Spring is finally coming and I'm taking my car in for its 4 year service, oil change etc. I didn't know if the cooler plugs have the same life span as the OEM plugs. The only thing I hate about changing the plugs is that the labor is so much and you have to practically take off the entire back end to get to them.
Jay
Jay
Jay
Jay
I noticed the last time (the dealer changed them) the gap was almost double ~.048...may have shortened life also. Running Denso Iridium IK22 as suggested by Scott...
Good luck,
DC
Only difference here is that I found with a tune, it seems to kill the plugs faser, especially if you do not have them gapped down to .025. I would say when you start getting a slight hesitation/sputter/miss around 4-5K RPM..Time to change them. Mine lasted about 11K from brand new , with a tune....then missing occurred. Changed the plugs and coils and runs like a champ!
Good luck,
DC
Good luck,
DC
Jay
if you have a tune, you should change plugs every 12k miles (just like the factory recomends for the gt2). if youre one of those people that idle their cars until they warm up, you should change it even sooner.
Trucker
There is also an issue of eventual seizing (at least getting pretty tough to pull out...) of spark plugs in the aluminum heads after many many years of thermal cycle and corrosion. So I am guessing 4-5 years is not a bad idea...
Also...on what the manual says (60K)....that does not apply when running a tune and other mods. I do not think anyone has ever gotten 60K on the plugs with a modded/tuned car? I could be wrong, but would be damned impressed if they did
If you are good with Google, you can find the whole set for under $300.
DC
It takes decades to arrive at that point. A 10 year old 20.000 mile car will never ever have problems with seized plugs. At least if you do not park it in water
In the latter case wet enough on two occasions to misfire.
Whether from washing or being out in the rain the engine gets wet enough the belt slips until the engine runs from anywhere from a few seconds to nearly 30 seconds until the belt/pulleys dry enough the belt is able to spin the alternator.
Even if you do not wash the car and do not leave it in the rain, moisture at the plug/head thread interface doesn't have to come from the outside. Combustion produces moisture and the pressure can force the combustion gases up between the threads of the plug and head where corrosion will occur. Upon removing plugs often the threads nearest the chamber are discolored and showing signs of corrosion while the threads further away are almost new looking.
It is risky and false economy to forego periodic and timely changing of the plugs.
Thanks for all the information guys. From the looks of it I will probably change the plugs again and coils at the 20,000 mile check. Bringing her in soon for the 4 year check including oil, filter, and new steering wheel coming from DCT motorsports. I'll post a pic after install.
Jay
Jay
I have experience working on old engines left in the open, left sitting in a car for decades. Alloy Alfa engines with sparks on top , so water stays in the holes, etc.
Plugs of our cars do not see water from the outside as they are well protected in the sides of the head. And more importantly , water evaporates before it reaches that threaded part of the plug form the outside.
Combustion moisture will eventualy take its toll but as I said , not after such a short time. It'll take much longer.
The heat cycles is what makes them seize eventualy and that comes from mileage. Not age.
Daily very short commutes takes of course a different approach as it greatly increases wear on everything.
