COBB Announces Porsche 911 Turbo Support
Basic Sponsor
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
![](http://www.cobbtuning.com/v/vspfiles/photos/categories/70931.jpg)
As many of you may already know, COBB is now offering Accessport and Accesstuner support for the 997.1 Turbo and GT2. We would like to take a moment to formally introduce our product and it’s capabilities.
![](https://static.cobbtuning.com/cobbtuningweb/site/images/accessport/v3-screen.jpg)
Let’s start with the Accessport. Our current support covers the 997.1 Turbo and GT2 with additional 997.2 Turbo support coming soon. We’re continuing to investigate 991 Turbo support along with expanding to various other models within the Porsche lineup. As part of a special release program, the Porsche Accessports are available exclusively through our Certified Porsche Protuners. The purpose behind this is to ensure our earliest customers are working with performance tuning facilities that we know are familiar with the vehicles and are able to provide the highest levels of customer service that the COBB experience is synonymous with. This collaboration also allows us to gather the various Porsche ECU ROM files as quickly as possible to further expand Accessport support. The special release program has proven to be an invaluable tool and we are happy to announce the release of the Porsche Accessport to all COBB Authorized Dealers and the COBB Website is coming very soon!
Accessport Features:
Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data.
Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
The Accessport connects to your vehicles OBDII port and is able to reprogram the factory ECU with a performance calibration file. During the installation process, the Accessport will identify and save the factory data from the vehicles ECU. That information remains stored on the Accessport and can also be backed-up on your computer using our Accessport Manager software. Should you ever need to return your vehicle to stock , it’s as simple as completing the Uninstall function with the Accessport. After the vehicle is identified, you will choose a calibration file that is applicable to your vehicle and modification level. We will offer an assortment of Off The Shelf (OTS) maps that will be preloaded onto the Accessport. You can also choose to have your car custom tuned by a Protuner who will use our Accesstuner Pro software.
COBB OTS Maps :
Stage 1 maps are calibrated to be used on a completely stock vehicle but still provide a significant increase in performance.
Stage 2 maps are to be used with an upgraded exhaust. We recommend using the stock airbox and upgraded intercoolers at this level.
Stage 3 maps will support our COBB 1000cc injectors on cars that are using E85.
Non-Performance:
Valet Mode
Anti-theft Mode
Installed Stock Mode
We are continuously working to refine and perfect our tunes, those updates will be available to customers at no charge.
Power Gains:
2008 911 Turbo OTS Map Power gains
2009 Porsche GT2 Stage 1 OTS Power Gains
2008 911 Turbo Custom tuned on E85
Modules that can be reset:
ECU/DME
AC
AIR BAG
AWD
All Wheel Drive
AWS
Bose Amp
Elec System
Front Body Module
Gateway
Instrument cluster
Left Door
Multimedia
PAS
PCM Gateway
Rear Body Module
Right Door
Seat Weight
Seat Memory
Stability
Steering Column
TPMS
Coming Soon:
Alarm System
Chronometer
Convertible Top
Targa Top
Suspension
Park Assist
Cornering Lights
Accesstuner:
![](https://static.cobbtuning.com/cobbtuningweb/site/images/template/pages/AP-page_05.jpg)
Have modifications that do not fit under our scope of Off the Shelf maps? Want to get just a bit more out of your setup?
Contact one of our Porsche Protuners to have your car custom tuned using our Accesstuner software.
Accesstuner Features:
World’s only custom tuning software for 997.1 Turbo
Most comprehensive offering of calibration tables
Control over fuel, timing, boost, VTG,
OTS maps unlocked – anyone can view
Upgraded injector support
Upgraded turbo support
Launch limiter control
Brake Boosting
Left Foot Braking
Individual Cylinder Knock Retard
EGT removal
VTG removal
E85 support
Cold Start Enrichment
Idle Control
![](https://rennlist.com/forums/signaturepics/sigpic141208_1.gif)
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
