997 Turbo Forum 2005-2012
Free VIN decoder
Old 03-20-2016, 09:07 AM
  #751
jhbrennan
jhbrennan's Avatar
Originally Posted by LUXEMBOURGER
Appreciate your maternal instincts, Juanna.
Not to sound overly patronising, in fact I did run http://www.vindecoderz.com prior to posting.
Result: it doesn't show cruise control. It is definitely on the car, which makes me question its credibility.
Hoping cam2008's engine is more reliable - or is it one and the same?
Cruise control is not an option...it's standard equipment...that's why it doesn't show up. Here's the build sheet. BTW, you can run it yourself - see post 330, page 22.
File Type: pdf
Old 03-21-2016, 11:53 PM
  #752
Rick GT3
Rick GT3's Avatar
please check this 2:
WP0AD2A91DS766122
WP0AD2A96BS766680
THANKS.
Old 03-22-2016, 04:21 AM
  #753
osunick
osunick's Avatar
If you just want the options, you can edit the following URL to get build sheets for most recent Porsches:
http://admin.porschedealer.com/repor...AD2A90ES166743
Old 03-25-2016, 09:07 PM
  #754
Black_997_c2
7th Gear
Black_997_c2's Avatar
Would really appreciate it if you could run the following:
WP0AA29965S715469
Old 03-25-2016, 09:14 PM
  #755
jhbrennan
jhbrennan's Avatar
WP0AA29965S715469
See post right before yours.
Old 03-25-2016, 10:20 PM
  #756
Black_997_c2
7th Gear
Didn't see that
Old 03-26-2016, 09:37 AM
  #757
Rick GT3
Rick GT3's Avatar
no luck with my VIN numbers?
Old 03-26-2016, 06:06 PM
  #758
jhbrennan
jhbrennan's Avatar
You can try it yourself - see post 753 right above.
Old 03-29-2016, 11:34 PM
  #759
AC/911's
AC/911's's Avatar
Cant use link in post 753?
Old 03-30-2016, 08:25 AM
  #760
jhbrennan
jhbrennan's Avatar
Maybe this one - substitute your VIN for the "XXX...'s"
https://admin.porschedealer.com/repo...XXXXXXXXXXXXXX
Old 03-30-2016, 11:46 AM
  #761
cam2008
cam2008's Avatar
Use this by copy and paste don't click on the link.
>> h t t p s://admin.porschedealer.com/reports/build_sheets/print.php?vin=XXXXXXXXXXXXXXXXX
not the >>>> put in your VIN and fix the HTTPS
you can actually copy the link above that Jim has and then modify for your VIN. whew how much work to explain when it seems so simple??
Old 03-30-2016, 11:53 AM
  #762
cam2008
cam2008's Avatar
WP0AD2A91DS766122 - NOT AVAILABLE
WP0AD2A96BS766680 - NOT AVAILABLE
THANKS.
Maybe Typo's? A9 ?
Maybe second A is a 9?
Old 03-30-2016, 09:48 PM
  #763
Rodbuster
Rodbuster's Avatar
Thank you very much for this info. It worked like a charm!
Have a good evening, Rodbuster
Old 03-30-2016, 11:10 PM
  #764
Rick GT3
Rick GT3's Avatar
Maybe Typo's? A9 ?
just verify both vin numbers and they are correct, don't know why NOT AVAILABLE.
thanks
Old 04-01-2016, 04:35 PM
  #765
cam2008
cam2008's Avatar
thanks
I see you are in Puerto Rico? Is the car from North America?
I can only get NA cars.
Quick Reply: Free VIN decoder
