Water on passenger floor pan, need help finding the source.
Hi Guys good morning, im in a little need of help here. Last time I left my car uncovered and raing really hard, I found a puddle of water on the floor of front passenger. It would only happen when it rains so no AC issues here. I took it to my mechanic, he blew cleaned out the sunroof and trunk compartment drains, and all common potential sources for water leaks into the cabin. Took it home rained again and I found water again. My mechanic told me he's puzzled by it and he believes most likely its coming from the windshield which is not OEM. The seal around the glass does indeed look poorly installed, and water may be running down the inside of the car right by where the right mirror is and into my floor pan, but I don't want to replace a windshield if maybe the culprit is something else. Any ideas? I am going to post some pics of my windshield so you guys may be able to tell me if that is what it is. As always your input is always appreciated.
Tape the window/seal border with say clear packing tape to seal it then douse the car with water and see if any appears.
Then remove the tape and repeat the process.
Or save money on tape and water and have the windshield redone. By someone better than the person who did the previous windshield.
That is an awful WS job.
Had one done early due to rock and the dealer brought in a WS monkey. WS whistled even at low speeds, would have leaked like a sieve if it had rained.
To their credit, he did it again with a competent guy.
Trucker
WOW!!!! Did you go to Windshield Monkey?
Is this a real Porsche glass? I forget who makes them, Sekurit I think? Or it can be the thinner Chinese glass. Which means higher noise transfer, chips, ..., star chip --> crack, etc.
Your carpet and the dampner material underneath must be allowed to be fully dried up now or you will get mildew in your car...You have to air it out completely, etc. Google the topic as I am not an expert.
Trucker
By the way...that is a bonded (glued in) windshield so perhaps it was not glued properly? At the factory the adhesive is applied by a robot in a full continious way and then the windshield is robotically installed and pressure applied until cure! kind of cool to watch.
And according to my tour guide, it's the only robotic assembly process on the line.
Dear MPIFFARETTI! You might want to try some permatex clear flowable silicone sealant. Flows like water, therefore finding all the pinholes. It may take more than i application, but it worked well for me on other cars...about 5.00 at AutoZone and other car parts stores. Thanks, Tiger 03447
Agreed that windshield is a little rough looking, but there is one more area to check that's easy. Open the frunk, and remove the battery covers and look below. There is a drain hole in the bottom on both sides (look with a flashlight) of that firewall that can get stopped up with crud.
I had a leak in my 997tt when I first got it, and those were filled in mine (at 24k miles). That wasn't my culprit, but it has been in others with the 99X platform.
thanks guys! but this is an old thread! the water issue has been fixed, it was a semi- clogged drain hole, so it would only overflow if it rained hard continuously, hence the intermittent problem. My car spends a lot of time on the road, so I expect little things like these to pop up with normal use. thanks for the input as always!
Yes, check the two drain holes on either side of the battery tray. Over time crap will build up and plug them. After a few hard rains it will fill up and start looking for places to drain in to.
