997 Turbo Forum 2005-2012
Best OEM tire pressure
Old 07-31-2013, 11:56 PM
C2 Turbo
C2 Turbo's Avatar
Default Best OEM tire pressure
Stock OEM size MPSS so what's the optimum street tire pressures F/R?
Old 08-01-2013, 12:19 AM
eurotom
eurotom's Avatar
Manual states 33/39 for partial load and that is what I run.
Old 08-01-2013, 08:42 AM
rotesAuto
rotesAuto's Avatar
Location: North Carolina, '12 cls63 '14 S550V4, 07TT-gone, 07Targa4S-gone
I'm usually sitting at 37/42, after they warm up
Old 08-01-2013, 09:44 AM
TT Surgeon
TT Surgeon's Avatar
Old 08-01-2013, 10:33 AM
4ocious
4ocious's Avatar
+1 But, both sensors on my left side just failed so I'm replacing them all along with the stems. If you need to replace yours I suggest calling Suncoast for OEM; they are less expensive.
Old 08-01-2013, 10:53 AM
Terry Adams
Terry Adams's Avatar
I like 6 lbs between F and R, in the range of 34/40 cold, 37/43 hot.
Old 08-01-2013, 01:24 PM
C2 Turbo
C2 Turbo's Avatar
Originally Posted by TT Surgeon
37/40
Cold or warm
I am sure, we can set the PSi number for TPMS, right?
Old 08-01-2013, 01:44 PM
eurotom
eurotom's Avatar
Cold. TPMS does not have setting for hot/temp, only partial or full load.
Old 08-01-2013, 01:45 PM
512bb
512bb's Avatar
I run 31/36 cold with Pilot Super Sports. Works really well with the suspension set-up I have.
Old 08-01-2013, 01:56 PM
steve k ny
steve k ny's Avatar
32 front 36 rear cold on mpss
feels great.
i run 30 and 34 on my r888s
Old 08-01-2013, 02:18 PM
C2 Turbo
C2 Turbo's Avatar
I set mine up at 33 F and 36 R (Cold) and though car feels great but the TPMS keeps saying "-4 psi" in rear
What do I need to do here?
Are they pre-set at certain numbers from the factory? Do I need to reset the TPMS?
Old 08-01-2013, 02:20 PM
TT Surgeon
TT Surgeon's Avatar
Street 37/40 hot
track R tires 32/36 hot (big track like wgi)
Old 08-01-2013, 04:37 PM
Superman32
Superman32's Avatar
I am going to use my P zero Trefeo on street. What pressure should I run on street?
Will higher pressure cause a big performance decrease? on track I run 30/33 hot.
But I am not sure I should run that low on street
Old 08-01-2013, 05:03 PM
512bb
512bb's Avatar
The TPMS is expecting 33/39 and if it drops 4 PSI below that the warning comes on. So you may consider going to 37 PSI in the rears and see if your tire gauge and TPMS are in synch. I have a very good tire gauge and my TPMS is consistently off by 1 PSI. That's one of the ways I avoid the dreaded !
Old 08-01-2013, 05:24 PM
eurotom
eurotom's Avatar
^ I see a bigger variance in TPMS vesus a quality gauge. More like -3 PSI from actual.
Quick Reply: Best OEM tire pressure
