clutch going out?
clutch going out?
I think my clutch is going out... it engages at the very top of clutch pedal movement and it's very hard to get moving in 1st. I have also had a few occasions where it has slipped when going from 1st to 2nd at full throttle. How does a clutch wear out on a car with 36k miles? Is it normal for them to wear out so fast?
I am thinking of upgrading to a sachs stage 2.5 clutch, sounds like a great upgrade without any downsides.
If the engine at any time gains rpms with the vehicle speed not increasing in perfect sync the clutch is slipping. No need to keep on accelerating. No need to repeat the test. The slipping just heats the FW and can ruin an otherwise perfectly good FW.
Be sure the brake and clutch fluid (really the clutch fluid in this case) is fresh. A proper clutch fluid flush and bleed can really improve clutch action. It almost certainly won't stop a slipping clutch from slipping though.
Also, before you condemn the clutch outright be sure the engine and tranny mounts are all in good shape.
How should I inspect tranny and motor mounts? Can that really affect clutch engagement?
I may need to flush the clutch fluid. I had my accumulator replaced not long ago. Tried putting it in 4th and stepping on it and it just pulls like it should. The slipping only seems to happen in 1-2 during fast acceleration. Maybe the clutch isn't fully engaging before I'm stepping on the gas? I would like to think it's not driver error...
Yea it's really just the 1-2 shift for me. Happened a few times, both before and after getting the accumulator fixed. Engine just revs like there's no clutch engaged . I've only had the car for about a month though.
Maybe tomorrow I'll get some quality backroad time to do some experimenting. If I try to 'test my clutch' near home I'll probably get indefinitely detained or sent to gitmo. Yay Virginia!
I've done this with the car (my Boxster) backed up on ramps. The Turbo I gave the mounts a casual inspection once or twice but let the techs inspect these more thoroughly when I have the car in for service. The techs know what to look for and where and how. While there they can look for early water pump trouble sign, fluid leaks, CV boot issues, etc.
Anyhow, if you're going to try this yourself you need a real good light and some knowledge of what good or bad mounts look like.
Really though, unless you are experienced this is probably a job for your favorite tech.
Driver error reads like a possibility: That the clutch doesn't slip in 4th says to me the clutch is basically good. So far.
(4th is the best gear as it is the one closest to 1:1 so the torque is not multiplied or divided by the transmission.)
Are you sure you are not getting on the gas too soon or off the clutch too late?
This is clutch slippage but of the self inflicted kind, and if not stopped can lead to clutch slippage of the permanent kind.
Before going too much further you really need to be sure the fluid is flushed and bled and right. It is far cheaper to do a proper clutch fluid flush/bleed than a flush/bleed along with a clutch job that is premature or even unnecessary.
