More questions regarding my level 5 dealor overrev
Guy i have level 1, 2, 3, 4 and 5 occuring at exactly the same time on the readout. It that how it works or is that not correct ino? Thanks so much...
You should scan your read out and attach it and you will get the experts to interpret it for you.
And In the last couple of months Excellence had a decent article on the over-revs. Sorry, I cannot remember which month but it was the last couple. It was a part of PPI article.
Going by memory (& I had to deal with this -- long story):
Level 1: 6800-7000rpm
Level 2: 7000-7200rpm
Level 3: 7200-7400rpm
Level 4: 7400-7900rpm
Level 5: 7900-9000rpm
Level 6: more than 9000rpm
If you get a L5 count, you will also get L1, 2, 3, 4 counts as well. So as the rpm goes up you trigger the count in each level.
if this was a one-stroke bad day, i.e. money shift, times will be obviously close(seconds or fractions of). High likelihood is this occured post-trade, dealer or independant broker/re-seller etc. Bottom line, though, is if this is a legitimate 5, where, when, how and why it happened is totally immaterial.
