997 Turbo Forum 2005-2012
997 TT Audio Upgrade & LED Tail Lights w/ sport chrono working
Old 02-13-2013, 06:44 PM
DELREYCUSTOMS
Former Vendor
DELREYCUSTOMS's Avatar
Default 997 TT Audio Upgrade & LED Tail Lights w/ sport chrono working
The Alpine INE-W927HD has everything you need through its 7-inch WVGA touch-screen monitor: A customizable My Favorites screen, built-in HD Radio tuner, Bluetooth® wireless technology and 3D Navigation. Plus you get Pandora and SiriusXM compatibility. All this amazing technology at your fingertips and it comes in the easiest to use AVN unit on the market. The INE-W927HD also features Visual Enhancement, a new technology that provides a more balanced picture, not over-emphasizing dark or light areas, so movies are seen with greater clarity. All of the graphics are crisp and clean for your viewing pleasure.
Overview
7" WVGA High Resolution Touch Control Display
50 Watts x 4
Three 4-Volt Pre-amp Outputs
CD/DVD, AAC, MP3, DivX Playback
My Favorites screen
Built-in Navigation w/ 3D & 2D mapping
Bluetooth® Hands-Free Calling & Audio Streaming
Android™, BlackBerry®, and iPhone® Pandora® Control
Works with iPod® and iPhone®
Built-in HD Radio™ w/ iTunes Tagging
SiriusXM SXV200 Tuner Ready
Powered by DRC Media LLC & Al & Eds Autosound
Old 02-13-2013, 06:45 PM
DELREYCUSTOMS
Former Vendor
Old 02-13-2013, 06:46 PM
DELREYCUSTOMS
Former Vendor
Old 02-13-2013, 06:47 PM
DELREYCUSTOMS
Former Vendor
Post
WE ARE NOT RESPONSIBLE FOR ANY DAMAGE.
we always recommend professional install this is a walk through for the D.I.Y 'er.
Some led tail lights trigger an error code or warning light on your dash. LEDs do no have the same resistance as regular bulbs. Resistors in series will eliminate those issues so no warning check engine lights come on the dash. We use two resistors in series to reduce the amount of heat that they generate, make sure to tap onto the signal wires only. We always recommend soldering your connections but the the do it yourself, t-taps will work fine. Make sure they are tight and snug when plugging them in.
Old 02-13-2013, 08:32 PM
jhbrennan
jhbrennan's Avatar
997 turbo Audio & Tail Lights
Overview
50 Watts x 4
My Favorites screen
What about the PCM funtionality that allows users with Sports Chrono to use the PCM to set individual memory items for things like DRL, etc. How do you access that with the Alpine or can you?
Old 02-13-2013, 10:00 PM
DELREYCUSTOMS
Former Vendor
THe sport chrono allow the car to over boost for 10 seconds. when the "sport mode" is pressed on the dash below the AC it activates this mode. It is not a PCM but an ECM feature. We have tested it on several turbo's and the sport is defiantly a reason why the TT are monsters.
As long as you preset the DRL before you unplug the radio the car will remember these items.
The only thing lost is storing lap times but to be honest when you are on the track your going wreck trying to record lap times. great idea by not real world practical unless you recording your daily commute and the Alpine has a built int trip computer.
excerpt on sport chrono from WIKIPEDIA
The optional Sport Chrono package allows the 911 Turbo to overboost for ten seconds, increasing peak torque over a narrow RPM range.
According to official Porsche figures, the 997 Turbo accelerates to 100 km/h (62 mph) in 3.9 seconds with the manual transmission, and 3.7 seconds with the Tiptronic S transmission. It also recorded a 60 mph (97 km/h) time of 3.2 seconds when tested by Motor Trend, eclipsing all of its major competitors and even Porsche's own Carrera GT supercar. The 997 Turbo has an official top speed of 318 km/h (198 mph), though Jeremy Clarkson achieved an indicated speed of 322 km/h (200 mph) during his 2008 video special.
Old 02-14-2013, 08:11 AM
jhbrennan
jhbrennan's Avatar
My question had nothing to do with Sport Chrono and over boost - it had to do with using the PCM to program certain features that without Sport Chron the dealer would have to program such as DRL's. You answered my question - the new head unit doesn't have this programming feature.
Old 02-14-2013, 06:53 PM
DELREYCUSTOMS
Former Vendor
the DTR on a 997.1 Turbo is just 2 small T-10 bulbs? as far as i understand
Old 02-15-2013, 04:58 PM
W211
W211's Avatar
Does it work with the multi steering wheel buttons?
Old 02-16-2013, 07:00 PM
DELREYCUSTOMS
Former Vendor
Does you steering wheels control work for volume and station tuning now?
Old 02-17-2013, 10:18 PM
W211
W211's Avatar
Yes, including answering calls, zooming in and out of navigation menu items, etc.
Old 02-18-2013, 03:50 PM
DELREYCUSTOMS
Former Vendor
the swc with work with the alpine or kenwood units.
the maps auto zoom on the new units. but phone, volume and track will work
Old 02-20-2013, 08:11 PM
DELREYCUSTOMS
Former Vendor
Default 2013 ALPINE G500 SOFTWARE UDATE INE-S920HD, INEW927HD, INEZ928HD
Firmware Update v1.201 (INE-Z928HD, INE-W927HD, INE-S920HD and IVE-W535HD) Contents
Improves hands-free telephone user interface
Enables access of dial pad, history, recent calls at all times
How to update your INE-Z928HD, INE-W927HD, INE-S920HD or IVE-W535HD
Download instructions here:
Unzip the downloaded update file folder to a freshly formatted USB memory thumbdrive. Do not change the file name.
Connect USB memory thumbdrive to the USB connector of the INE-Z928HD, INE-W927HD, INE-S920HD or IVE-W535HD.
Press “OK” button when update message appears on the screen.
During the update, a progress bar will appear. It will take about 5 minutes to complete.
When the firmware update is finished, your INE-Z928HD, INE-W927HD, INE-S920HD or IVE-W535HD will restart automatically.
Turn off the vehicle’s ignition, remove the USB memory device and turn the ignition back on to finalize the firmware update. Confirm the firmware version number displayed as “1.201” (depending on your unit) in the Setup Menu of the INE-Z928HD, INE-W927HD, INE-S920HD or IVE-W535HD.
WARNING: This firmware update is specifically designed to work with units sold in the U.S. and Canada. Using this firmware update on units sold outside the U.S. and Canada will damage the unit. If you are not sure if you need this update, please contact customer service for help.
here is the link to take you direct to Alpine site http://alpine-usa.com/feeds/promo/13avupdate
Old 06-08-2013, 05:16 PM
DELREYCUSTOMS
Former Vendor
Default 997 PCM Upgrade Porsche Nav Tv HUR-997 with Steering Wheel Controls
Allows the retention of the factory BOSE Amplifier and speakers when adding an aftermarket radio to 911, Boxster and Cayman vehicles
Not compatible with 2005 911 Turbo / 996 Chassis with Black faced radio.
The MOST-HUR/997 provides audio integration into the stock amplified sound system, allowing the end-user to replace their factory radio with an aftermarket Navigation/DVD head unit, while retaining the factory amplifier and speakers. Installation is easy, with only 5 wires connected to the vehicle, an included antenna adapter and a MOST fiber optic extension. The MOST-HUR/997 supplies accessory power, illumination, VSS (vehicle speed pulse), foot brake, parking brake signals and infrared steering wheel commands to Kenwood or Alpine (only) aftermarket radios.
Note: If the vehicle does not have the Bose audio system, the speaker connections will need to be hardwired to the factory harness from the original radio. Also, the subwoofer in some vehicles uses a secondary amplifier, which also needs to be directly connected to the aftermarket radio.
A high-quality Double-DIN dash installation kit in either Black or Silver is also available, and is highly recommended for a professional looking install.
With a large 7" WVGA screen, My Favorites screen, easy sound setup, navigation and built-in Bluetooth® wireless technology, the INE-W927HD offers fast access to your favorite entertainment and information sources, and has several new features that can be tailored to you and your vehicle.
Overview
50 Watts x 4
My Favorites screen
Steering Wheel Control compatible
http://www.ae-33.com
http://www.facebook.com/AEMarina33
http://www.twitter.com/delreycustoms
http://www.yelp.com/biz/al-and-eds-au...
Old 08-31-2013, 11:02 PM
DELREYCUSTOMS
Former Vendor
Default GPS Antenna Placement when Upgrading Your Porsche PCM
TTEMPT AT YOUR OWN RISK! WE ALWAYS RECOMMEND PROFESSIONAL INSTALLATION. WE CANNOT BE HELD LIABLE FOR ANY DAMAGE TO THE CAR OR YOUR EQUIPMENT PLEASE PROCEED WITH CAUTION AND THANKS FOR WATCHING.
WE SHIP ANY OF OUR PCM SOLUTIONS PLEASE FEEL FREE TO EMAIL ME WITH ANY QUESTIONS SATURNDRCMEDIA@GMAIL.COM
DIY Install Video For mounting GPS antenna and Sirius Antenna when doing a DelReyCustoms PCM upgrade Package Featuring the Alpine INE-W927HD & NavTV KIt-210 HUR-997. This Video is to help with the antenna placement and wiring. It also show where to run the cable thru the fire wall. This is only to Help with install.
Were Running a LABOR DAY SALE ON THE ALPINE PCM 1 package email me for details.
http://www.yelp.com/biz/al-and-eds-a...marina-del-rey
Quick Reply: 997 TT Audio Upgrade & LED Tail Lights w/ sport chrono working
