Gas Tank Float/Sensor Problem
My car sat for a week and when I came out to start it my gas tank gauge showed empty and the low fuel warning light came on. I knew I had a 1/2 tank of gas so I took it to my local gas station and as I suspected could only add 1/2 a tank. Upon starting the car the gauge registered 1/2 a tank and as I drove it it climbed slowly to full. Anyone else have this problem or hear of it?
It is possible if a hose came loose or depending upon where the hose came loose allowing it to whip around this hose could jam (interfere with) even damage the fuel level sensor/sender system.
Or it could just be a going bad fuel level sensor/sender. There's nothing special about these they can fail just like any other sensor/sender.
BTW, after 1/2 tank the on-board computer takes over the fuel level function calculating the fuel level based on various factors.
I think you are faced with taking the car to a qualified shop for a pro's diagnosis: The problem ain't going away on its own.
Sincerely,
Macster.
