ARBs and spacers
ARBs and spacers
I am considering a 997TT.
I do not do any track driving, but I do drive in the mountains from time to time.
Are aftermarket anti-roll bars a worthwile investment for a 997TT or is the OEM suspension good enough?
Also wonder about spacers, anyone installed some?
For an occasional mountain drive I think that a more aggressive alignment would be the best, low cost option. At the most, you could do an alignment and sway bars as the TT is fitted with soft ones.
As far as spacers is concerned as long as you have the proper lug bolts to go along with them, you are fine. I just did the stud conversion since I track the car and the studs allow the use of spacers if needed.
