Experience with Akropovic?
4th Gear
I have been looking to upgrade the exhaust system on my 2011 TurboS. The front runner is the Fabspeed Stage 2 setup but recently I was introduced to the new Akropovic system for the TS. They now have a 200 cell system which I am told will not affect the Check Engine light.
The setup is designated L-PO997TFLS-200 Link pipe set (200 cpsi cats).
I would appreciate any experience, insights, concerns
Akrapovic is the best system from performance/weight point of view on the market, also used by porsche on gt2 rs (and box on GT2s). Best non-Ti system is europipe.
ECU would adjust - there is a bit less backpressure leading to faster boost and a bit lower turbine temps - all within default maps. Obviously you can tune things further, even maps that had been adjusted - for marginal benefit unless engine dyno is used to fine tune.
