Ruf RGT-8
I heard it was a 3.4L flat 8, obtained from the porsche motorsports development dept, with whom they are tight. This is the same motor the Hurley Haywood tried to get them to produce for the gt3rs/rsr a couple of years ago.
Lightweight-8-Cylinder-90°-engine with racing DNA
180° crankshaft “Flatcrank”
4,5 Liter displacement
Power output 404 kW (550 bhp) @ 8500rpm
Maximum torque 500 Nm @ 5400rpm
Aluminium crankcase and cylinder heads
Water cooled, cylinderheads and engineblock cross flowed
4-valve system with spherical layout
4 camshafts with hydraulically timed valve system for in- and outlet
Hydraulic valve tappets
Dry sump oil lubrication with two windage trays for each of the 4 chambers
Individual chamber oil suction with 2 suction intakes
Waterpump, generator and AC compressor are directly driven of the Engine (no belts), located at the lowest position
Sequential fuel injection system
Individual cylinder ignition coils
Electronic engine management system
Electronic throttle control system per bank with 2 butterflies
3-Way catalytic converters with stereo closed loop lambda control
On-Board-Diagnosis for continuous monitoring of the exhaust system
![](http://gallery.me.com/bobbywu/100315/4402122479_7761215d55_o/web.jpg?ver=12675798810001)
I still say as I always have that Porsche should move to a flat-8, which would mean a lower COG than the V8, and that would continue the evolution of the 911.
